Rebuilt Motor Timing
I've just completed the recommended 20 minute break-in run at 2000 RPM on my newly rebuilt 2.0 T4 and need to tweak the timing a bit. Is it okay to run the motor up to 3500 RPM to set the recommend 27 degrees BTDC this early in it's life?
Jack
Old 09-14-2012, 08:29 AM
yes, you should be fine now to go up to that limit. You running break in oil?
Old 09-15-2012, 09:33 AM
Timing
Yes, I still have Brad Penn break-in oil in the motor.
Jack
Old 09-15-2012, 12:55 PM
