Smile fuel pump/reg for carbs...recommendations?
I currently have that round chrome thing from a PO and a small rotary electric FP that doesn't shut off until the ignition gets shut off at the switch ( key). This car came with a factory (25psi, yikes) pump with webers, and I've heard about something called a facet/fasel or something like that for VW applications that's supposed to be good. What's the cleanest setup?
Old 06-11-2002, 06:50 AM
Scott S's Avatar
Yep, it's a Facet (sp?). There are two different types that I have seen/used, the only difference being the PSI. I think one is 2.5 - 3PSI and the other is up to 5 PSI. I would also reccommend a fuel pressure regulator. Both the pump and the reg are available at 99% of local auto parts stores.
I have had a fairly new pump fail in the past, so I keep a spare with me. Pretty cheap insurance.
- A pile of British stuff
- A growing pile of German stuff
... oh, and two Hondas - complete with car seats and pounds of fish crackers smashed into the carpet (and seats, and door pockets, etc etc etc....)
Old 06-11-2002, 07:50 AM
914 Geek
Facet pumps are cheap and noisy. Put them on rubber isolation mounts or the clacking will drive you crazy.
...It might anyway, but some of us have a shorter journey to get to "crazy" than others.
--DD
Old 06-11-2002, 09:07 AM
You will probably wire the pump so it stays on whenever the ignition is turned on. If your rotary pump is the correct PSI, I wuld stick with it-it will be more quiet than a facet. You can also get pressure regulators at your FLAPS if its output is too great.
Old 06-11-2002, 09:21 AM
