John Rogers's Avatar
Compufire Distributorless Ignition
Has anyone used the DIS-IX Distributor Less Ignition Module made by Compufire? I use their magnetic pickup in both our cars and they are great and this eliminates the high voltage inside the distributor cap, rotor, etc. The price I saw at an off road shop was about $275 or so?
Old 06-14-2002, 01:00 PM
Scott S's Avatar
I am very interested in this product as well. Almost went this route but ended up with the MSD as I could not find anyone who had ever installed/used it.
Anyone?
- A pile of British stuff
- A growing pile of German stuff
... oh, and two Hondas - complete with car seats and pounds of fish crackers smashed into the carpet (and seats, and door pockets, etc etc etc....)
Old 06-14-2002, 02:29 PM
Its like a crank fire, only its on your distributer so there is some added slop.
It was designed for the 009.
It needs to be modified for some/all type 4 dizys. Jake does them.
The owners at shoptalk like them.
I understand it also fires on exhaust so there is another module to get the tach to read correctly. See the link..
http://www.empius.com/i/ignitionkits.html
-Rich Hilgersom
Old 06-14-2002, 02:47 PM
airkwld's Avatar
Not exactly the same type of unit, but I run an electromotive setup and am very pleased with it. No distributor at all.....
More info at: http://www.electromotive-inc.com/products/hpx.html
Old 06-14-2002, 05:22 PM
JmuRiz's Avatar
How difficult is the electromotive unit to set up? Just curious, I have a Crane xr-3000 and have it dialed in...got rid of my points and in the process got rid of the popping and missing I always thought was my carbs' fault. The electromotive system looks the best of all.
Nathan
'73 2.0 914 (2.8 /6 conversion in progress)
'64 356SC
'65 Ducati Falcon 80
‘19 Audi SQ5
Old 06-14-2002, 08:07 PM
airkwld's Avatar
Not to bad once you get past the sticker shock.
The PO had it (professionally) installed.
I have since reworked the installation and wiring.
Since you are local to Electromotive, they are in
Manassas, tech support is easy. They have been great to
deal with. I needed a plug for the dist. hole b/c it
was left installed and I wanted it out. I used a rubber boat
drain plug. Also, I have seen a rubber expand type of freeze plug
used. Dialing in advanve is easy. If I get it out this weekend I will take some pics of the unit. The wiring to the relay is still sloppy, still working on it.....
Old 06-14-2002, 08:28 PM
I have the Electromotive setup in my modified Honda Civic Si. It's a bit of an overkil if you are just trying to get rid of the point. Also, as previously stated, it's quite pricey.
Old 06-15-2002, 02:06 AM
