Zeke's Avatar
Broken rear suspension bolts
This is a cross post from one I posted on STF. But the fact remains that I broke off three of the six bolts that hold the trailing arm the the console. Racer Chris replied over there that, indeed, this is not a good thing. So far I have about six hours in trying to remove the bolts by every means I can think of including soaking with various oils, heat, screw extractors, impact with a BIG hammer and drilling through to possibly retap.
I went ahead and drilled one of the threaded sleaves out to 7/16ths for a through bolt, but that ruined about every drill bit I had including colbalt (about $50 worth). I even bought myself a Father's Day present, a drill bit sharpener. (Good for dressing up dull bits in otherwise good condition, but I toasted mine. It's a little hard pushing the drill motor up with all your strength and trying to squirt oil on the bit with the whole mess raining down on you.) This is the hardest metal I have ever encountered.
Anyway, any ideas? Thanks.
Old 06-16-2002, 07:24 PM
Jim Smolka's Avatar
Not sure why the bolts are stuck so tight.
For drilling the bolts, the guy who runs a local nut and bolt house sells drill bits that go through 12.9 steel at an amazing rate. These drill bits are not cobalt, but they work great!... I'll find the mfr and get back to you
Another option is to drill a hole smaller and then use a reverse drill bit.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 06-17-2002, 02:41 AM
canna change law physics
red-beard's Avatar
Hey Zeke, I feel your pain.....
You dulled a colbalt bit ??? I rounded off a good high speed steel bit going after the broken tap. I was thinking of the same father's day gift....
James
James
Red-beard for President, 2020
Old 06-17-2002, 05:06 AM
Zeke's Avatar
I didn't break a tap.....yet. I'm still after the remains of the bolt. Day four...................the saga continues.
Old 06-17-2002, 06:48 AM
red-beard's Avatar
"I didn't break a tap.....yet."
You still have time...
Good Luck!
James
Why don't they make portable automotive lasers yet? Can't you see it?
"Man I stripped a stud today. Need a laser drill."
"Uh. Do ya want the 5 watt or the 15 watt unit, dude?"
James
Old 06-17-2002, 08:33 AM
Zeke's Avatar
Oh there's a guy here in Long Beach, The Hole Shop, that can do onsite bolt removal, but even his in house services are outrages. All the auto repair shops send their heads to him. He does oil field work and pipeline (valves) as well. I'm not sure how his portable equipment works.
Update: 9 PM- The last of the 3 are drilled out for 7/16th bolts. Titanium bits in steps of 1/16th at 300 rpm is the trick. Expensive trick, just the last one, 29/64ths cost over $20.
Old 06-17-2002, 12:09 PM
