Backdating Front Bumper?
I am backdating the front bumper on my 73 to a pre-73 bumper without the bumperettes.
Somehow the early bumper appears not to mount as close to the front bulkhead leaving a 3/8" gap between the front of the hood and the rubber bumper top. ![]() Unfortunately, I no longer have the original bumper to compare. Are there differences between the early and late bumpers other than the tits? Any help will be appreciated. TIA Last edited by seventythree; 12-16-2012 at 07:32 AM.. |
914 Geek
There should not be any other differences. Sounds like either the new bumper is tweaked, or the old one was tweaked to match a tweaked front panel.
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Trim the dog bones thinner to get the bumper closer to the front hood / fenders.
Trim too much and you are screwed. |
Update:
I mounted the bumper and once the mounting bolts were torqued, the bumper positioned much closer than initially thought. ![]() However, I was contemplating the idea of trimming the dog bones. I wasn't sure how hard that would be? I imagine they need to be cut as opposed to a lapping action using very coarse sand paper on a flat surface. Also, if the steel sleeves in the bolt holes control the spacing, they must be trimmed as well. Correct? Thanks for all input. |
a belt sander would make quick work of the rubber and metal inserts. If you have a belt sander that would be one way to trim them in an effective way. Hold the part carefuly and you should be able to get a nice flat surface on it. Make sure the removal is even across the surface, else the bumper will be tilted!
excellent suggestion to trim the dog bones by the way. |
