Eat-um-up's Avatar
Send a message via ICQ to Eat-um-up Send a message via AIM to Eat-um-up
Solid Motor mounts
im just curious. I want to put solid engine mounts on my 914. its a side shift setup. If i put the tail shift engine braket on the the engine.. would it be the right lenth to just put a bolt though the crossbar without any sort of spacer between the bar and the engine?
72' 914
Old 06-23-2002, 01:07 PM
mr914's Avatar
I don't think it would clear.
A number of years ago, I made some aluminum blocks that were the same height as the rubber mounts and bolted the engine to the bar.
Let's just say, about 300-500 miles later, I replaced them with the rubber mounts.
Everything, and I mean everything will rattle loose. Like an old Harley Davidson.....
If your using it for a track event, the solid mounts are great. But for street use, it's another issue.
Never enough time to be doing the fun stuff.
'70 914-6 2.2 MFI #269
'71 914-4 2.0
'85 911 Carrera
Old 07-05-2002, 10:06 AM
Eat-um-up's Avatar
yeah its rattleing everything loose but im poor and ive actually gotta save for those mounts.. geeze how sad is that. thier not even expencive!
72' 914
Old 07-05-2002, 02:27 PM
made some trans mounts
Just couldn't see replacing the trans mounts so I got a piece of aluminum flat stock 1/2 " thick about 4"x6" and a piece of Aluminum pipe 2 1/2" thick 3" dia. welded the two together. Drilled hole in center for big bolt and hole in plate to mount to body. I cut thick rubber sheet to fit in hole of pipe. When I put this thing together it was so solid I smiled for miles. With the rubber inside preventing metal to metal contact I didn't hear any more noise than usual. That tranny stays put now.
Old 07-05-2002, 02:43 PM
Eat-um-up's Avatar
i used the top and bottem of the old mounts and some box steel. its real solid and dont rattle. but when riding the engine down a hill slowly or idle it skaes the car all over sometimes makeing everything else rattle
72' 914
Old 07-05-2002, 04:22 PM
