Barber Dave's Avatar
Thumbs up Sun Visors
Not being able to aford a pair of new visors, It was sugested that I have mine recovered. Has anyone done this? I know it would be expensive but has to be cheaper than the almost $600.00 I was quoted by A.A. Whats your experence??
THanks Dave
Rennlist Member
S.M.O.G.
914 Club
M.V.R.P.C.A.
73,BLACK ,2.0
Old 03-10-2003, 06:08 PM
kellzey's Avatar
Speaking of... does anyone know if visors from some other car would fit?
Qarl
Old 03-10-2003, 06:14 PM
Amark's Avatar
If your visors are intact & the vinyl is still soft you can repair them. I bought a pair on e-bay that had the disintegrating inner foam problem. I cut them open along the seam closest to the windshield & fished the wire frame out. I used the wire frame for a template to cut out two layers of 3/8" closed cell foam. Contact cement the two layers of foam around the edges w/ the wire frame sandwiched in the middle. Fish the cover back over the frame & foam. There is enough extra vinyl to overlap the seam and superglue it back together. You can run strips of masking tape 1/16" on either side of the seam. Apply a small bead of black RTV silicon that you smooth w/ your finger. Remove the tape after a couple of minutes and you are done.
Good as new, or as close as I could get.
Mark
73 2.0
Old 03-10-2003, 06:30 PM
Stay away from my Member
campbellcj's Avatar
Another idea -- the PO of my car fabricated some pretty cool visors in fiberglass. Apparently he just layed some mat & resin over a cardboard or plywood core, using the stock wire "frame" and hardware. Then painted them semigloss black.
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 03-10-2003, 08:54 PM
philinjax's Avatar
I had a set made from my old frames. Look quite good.
http://www.autosunvisors.com/replacement.htm
Phil
Old 03-11-2003, 07:43 AM
Goldfinger '72's Avatar
The PO of my teener made hardboard visors - i got rid of them quick - they looked as though they could take your nose off in an accident. (not that i'm planning an accident...)
Old 03-11-2003, 07:26 PM
chrisreale's Avatar
$600?????? Go buy some sunglasses and a newspaper
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/
www.914club.com
Old 03-11-2003, 08:23 PM
campbellcj's Avatar
I actually never really got the point of sunvisors. They block long-range (horizon) view and just kinda bug me. I wear sunglasses every daylight moment I'm outdoors or in the car anyway.
Chris C.
Old 03-11-2003, 10:07 PM
Phil,
Bunch of questions please.
Could you tell us the price? Also, what was the basic procedure? (Did you end them your old visors and hinge pins?) Were you satisfied with the service? What type vinyl was used?
Thanks,
Mike
Old 03-12-2003, 05:43 AM
i think these are a perfect fit/replacement. 600 beans for recovered visors? please tell me you're just winding aa up.
kevin
Old 03-12-2003, 06:17 AM
philinjax's Avatar
MAF 914,
I will take pics. and post on this tomorrow.
Phil
Old 03-12-2003, 01:24 PM
Visors
Phil & every one else!
I just got a responce from Vinyl Specialties , I can't believe it
They said $ 57.00, no sh-t!!!!!!!!!!
I emailed them to clarify , whether that included the pocket on the drivers side and the vanity flap on the passenger side( they would need my mirror probably) and if it was for one or two.
Phil PLEASE post pictures of yours & what it cost you.
Ever if it is $100.00 each with everything . That $400.00 less than A.A.s price , and our host wants $275. oo for one and doesn't have the other. I,ll let you all know what there ans. is.
DAVE
Rennlist Member
S.M.O.G.
914 Club
M.V.R.P.C.A.
73,BLACK ,2.0
Old 03-12-2003, 04:53 PM
Va914's Avatar
I haven't tried this yet but I have seen the post product and it looks great.
Remove the bad foam from inside the visor by any nondestructive means you can. Use a shop vac and make sure you have 99% of the bad foam out....
Buy a can of foam sealer from Lowes (the kind that gets real hard).
Put the visor in the sun to soften the vinyl up some. Spray the foam into the hole you used to remove the old foam from the visor. Once you have the visor filled put the visor between two sheets of plywood and with some weights apply pressure. Let this sit for an hour or so.
Finish off/clean up the over flow and you now have final product. It should be a good looking visor.
If this doesn't work you can always buy a new set
Kerry (Back on the road, sort of)
914-6 in the Werks
check out this thread from the 911 board, Restoring Sun Visors
some of the guys had tried the expanding foam without much luck.
doug
doug waters
70 914-6
dougwatersfotos.com
http://www.flickr.com/photos/dougwatersfotos/
Old 03-12-2003, 05:39 PM
philinjax's Avatar
Okey, guys, here is a pic of the visors I had made at a local shop. Cost me $60.00. No mirror or pocket. It was only after I had mine made that I found the autosunvisors site.
Phil
http://images.prosperpoint.com/1070/54506-88.jpg
Old 03-13-2003, 06:20 AM
Va914's Avatar
Thanks for posting the link to a past thread. It sounds like the foam idea has been tried and with no luck. I guess the search is still on for a good cheap ($) fix for the 30year old visors.
Kerry
914-6 in the Werks
Old 03-13-2003, 08:04 AM
Thumbs up Visors
Phil: Thanks for the pictures. I f Vinyl Specialties does as good a job were home free. I have a extra set of stock visors, I'll send them and when they return them I'll post pictures. They have a choise of patterns of vinyl,( I,m getting Madrid) . The price is $57.00 plus $7.00 shipping = $64.00 How can I go wrong?
Anyway I,LL let you all know. Dave
Rennlist Member
S.M.O.G.
914 Club
M.V.R.P.C.A.
73,BLACK ,2.0
Old 03-13-2003, 10:08 AM
I was away for several days and wanted to follow up on this topic.
Plil, Thanks for the photo.
Barber Dave, Please let us know the results. I'd spring for $64 apiece if the results are good.
I can't do $600 though!
Mike
Old 03-17-2003, 10:24 AM
jc9 jc9 is offline
$64.00 is a pretty good price. the materials are all available locally and easily found near any big city. u can buy the vinyl, new foam and make the insert out of masonite. use the old one for pattern. have the domesticated woman sew it up. vinyl is easy to cut and u can use the rest of what you bought for a new dash cover, sail panels or many other trim pieces. there is an upolstry supply house on bascom in san jose that sells a yard of nice black vinyl for about $6-7.00. they have all kinds of foam and leather products. the only hard part is the sewing but if you got it all ready to sew with allowances for seams then if you took it to a seamstress you should get a good deal.in san jose they would charge about at least a $100. because labor is high. jc
Old 03-17-2003, 11:42 AM
JWest's Avatar
Finding one of those is the hard part. Seems they were all released back to the wild during the 1960s
James
JWest Engineering
Old 03-17-2003, 12:15 PM
