Restoring Sun Visors
Okay, I believe we hit upon this subject awhile back and several ideas sounded worth investigating. Unfortunately I am drawing blanks!
I have the original sunvisors on my 73T which look like deflated air mattresses, but nonetheless still block out the sun. It seems that whatever they used to stuff them with made its way out in the form of dust over the decades. The visors have an internal wire frame that manages to help keep its rectangular shape despite the puffy drab look.
Now, the question is, what to stuff them with or how to restore the shape? I do recall, that expandable foam insulation was an idea, but the drawback was it dried out and deteriorated as well, especially in the presence of direct sunlight.
Anyone have any ideas?
Regards
Bob
73.5T
Old 02-28-2003, 08:04 PM
Administrator
Jack Olsen's Avatar
You should do a search, but I think one of the solutions involved cutting a pencil-tip sized hole, and injecting an expanding foam product used to fill and patch roof leaks. Then, you let the stuff harden while the visors are pressed between two large books.
Old 02-28-2003, 08:29 PM
Super Moderator
cstreit's Avatar
You got it Jack. What you want is the "Great Stuff" expanging foam material. You cut a small hole, inject it in untill it spews, then place the visor between two heavy books. Works like a charm.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-28-2003, 08:34 PM
crashr's Avatar
I just read a couple of the previous threads and with the exception of a few; the foam method doesn't work.
1975 Widebody 911 3.2 Euro
Old 02-28-2003, 08:36 PM
Administrator
Jack Olsen's Avatar
Great Stuff. Yes, I knew it was something like that.
Old 02-28-2003, 08:37 PM
Information Junky
island911's Avatar
It depends on the foam. Some need air to harden. Great Stuff seems to harden in the can if it's not used right away. Whatever foam is used, I would suggest, a test. Filling zipplock bag, for instance. And, WEAR GLOVES. . .they should call that "Stuff," "Greatly Sticky Nastie Expandable Goo"
(and yeah, crashr, I'm working the valve tool issue)
Old 02-28-2003, 08:48 PM
B58/732
BlueSkyJaunte's Avatar
Never had any luck with any of that foam stuff. Hot climes make it worse.
ΜΟΛΩΝ ΛΑΒΕ
Old 02-28-2003, 10:07 PM
beamonk's Avatar
Send a message via AIM to beamonk
I tried it, it didn't work well
John Brasfield
91 C2
78 SC For sale
76 3.6
68 Datsun 2000 Mr. Magoo, 02 330ci
Old 03-01-2003, 04:09 AM
Looks like its back to square one!! I can always inject goose down feathers but that's too messy!!!!!
Their has to be someway to restore these.........
All creative/inventive minds welcome.
Bob
Old 03-01-2003, 06:20 AM
Student of the obvious
LeeH's Avatar
I tried the foam on my last 911. What a mess. It was soft in places, and lumpy in others. Maybe the Great Stuff will work better than what I used. You have little to lose by trying.
Lee
Old 03-01-2003, 06:41 AM
walt's Avatar
I did mine but was not satisfied with the appearance, think I shot to much in. One of those - practice makes perfect things.
Walt
82SC 3.0
81SC 3.6
Old 03-01-2003, 07:21 AM
i accidently left one 914 visor out in the rain. it swelled back up to new. i was baffled.
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 03-01-2003, 07:23 AM
UTKarmann_Ghia's Avatar
Send a message via Yahoo to UTKarmann_Ghia
I have a similar problem. I believe the cardboard in the visors is ok, but it's like they are filled with air--kinda like a down pillow. I'm going to try to get some spray adhesive, make a small hole on each end of the visor, spray some of the stuff in it, then put some heavy books on top. I'm also consdering heating up the visors so that the plastic takes cooling shape more easily. Does this sound like it may work?
Matt
'82 911SC Targa!
Old 03-01-2003, 07:40 AM
Noel's Avatar
I had a similar problem with ballon looking sunvisors. While I considered foaming them, I ended up just buying new black ones and am extreramly pleased with them. (Even though they were alittle pricey.)
Noel
Old 03-01-2003, 09:09 AM
gregk1's Avatar
I thought about taking it to an upholstery shop, And have him run a stitch around the middle of it and make it have a roll and tuck type of look to it, What do you guys think??Just another Idea to try other than throwing them away and buy new
65 911/ 301274 sold
66 911 /303509 sold
67 911/ 355032
68 911 softie sold
70 T with s trim
Old 03-01-2003, 09:14 AM
Rob McKibbon's Avatar
Took mine off - same reason. Also 6'4" tall and my sight line is just below the windshield header and the extra inch was nice.
Now I carry two baseball caps in lieu of visors (or windscreen).
Noel: where did you buy replacements. Can you post a pic or 2?
Mine are just a joke, I didn't think they were originals as my car is a T converted to Cab.
Rob McKibbon, Shuswap Boy <><
To steal ideas from one person is plagiarism, to steal ideas from many is research.
Currently researching ideas for my '74 911 Cabriolet
Old 03-01-2003, 09:18 AM
Administrator
Jack Olsen's Avatar
Reproductions are available for about $50 each.
Old 03-01-2003, 11:03 AM
Randy Webb's Avatar
OK, I tried the foam -- worked but set so fast I couldn't get the books on top of it. Look for "slow set" foam.
Or -- strip the vinyl off and reapir the interior with palstic/felt/carboard. THEN stitch or have someone stich leather around the assembly. It'll be nicer than stock.
Old 03-01-2003, 02:41 PM
these basket balls are hard to see around, and the mirror makes me look fat.
206 637 4071
Old 03-01-2003, 02:53 PM
I tried the Foam in my visors, It worked great for about 4 or 5 months, I live in Louisiana so it is very hot and humid, the foam eventually broke down and I was left with what I started with 6 months earlier.My suggestion is to find reproduction visiors, I went with Performanceproducts and although they are not a factory match, they work like they are supposed to.
Old 03-01-2003, 03:43 PM
