Lines in drivers side tunnel
There are two lines (steel & flexable - about 3/8") which run from inside the left front fender well down into the drivers side diagonal to the back of the car.
Am I correct in guessing that these are for the air? Were all cars equipped with these lines even if there was no air instoled in the cars?
Bunch of old cars
Charcoal canister, I believe.
AC lines were run on the passenger side and were rubber hoses most of the way. They were also not factory installed and you could tell by the way the holes were cut (jagged edges and usually some rust). James |
The lines for the charcoal canister run down that side also.
From the factory they were plastic lines, but I have seen some that have been replaced with copper tubing and hose......
Never enough time to be doing the fun stuff. '70 914-6 2.2 MFI #269 '71 914-4 2.0 '85 911 Carrera |
