david.avery's Avatar
Anyone have CV specs?
Hello all
I have a bastard monster close to assembly... a 550 spyder with a Type IV motor and a 901 side shift.
I presently have unknown flanges, inner and outer, and am about to buy CV's and make up custom axles to fit. I was wondering if anyone knew anyone (or of any materials) that could help me discern what I actually have.
At present, here are my flange specs:
Inner (trans side)
93mm OD
78mm bolt spacing
Suspected: stock 914 (as the trans is side shift)
Outer (wheel side)
100mm OD
85mm "lip" OD
85mm Bolt spacing
Suspected: early 911 (69-) as the trailing arms were steel.
Thanks for any help you can give!
-DMA
Old 07-05-2002, 11:48 AM
Pictures too...
Hi folks
Took some pics as well... anyone have any ideas?
Old 07-08-2002, 10:38 AM
I am not really sure what you are asking but your transmission side flanges look exactly like the ones on my 901 transmission down to the alignment pins and bolt spacing. I would say they are stock 901/914 flanges.
Hope this helps
Old 07-09-2002, 11:25 AM
