-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   window regulator part-where do I get it? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/747074-window-regulator-part-where-do-i-get.html)
sundevil64 04-28-2013 04:36 PM
The plastic bushing is shot on my DS window regulator. I searched pelican and didn't see it. Where can I can get this? You can see it sitting at the bottom of the door.
http://i475.photobucket.com/albums/r...ps6eb18798.jpg
http://i475.photobucket.com/albums/r...psd98b9e40.jpg
Dave at Pelican Parts 04-28-2013 10:59 PM
I don't see the part listed in the factory catalog either. (It's available as a PDF that you can download from the Porsche Classic website.) The track is visible in the drawing in the catalog, but there does not seem to be a part number associated with it at all.
P/N 914.542.041.10 / 914.542.042.10 is listed as "power windows", L / R. That's the cable/track/channel part, as far as I can tell, and the bushing is probably sold as part of that assembly. (Hey, does that mean early 914s have power windows? Hand-powered, I guess.) Our catalog shows them as available for a couple hundred each, but special order with no returns.
My best suggestion at this point is to try to pick up the pieces and figure out the dimensions and shape of the bushing, and have a machinist make one for you out of Delrin or a similar material.
--DD
sundevil64 04-29-2013 04:29 AM
I was afraid you were going to say that. I saw an entire regulator for sale, but it seems like a lot of work for something so small.
Joe Ricard 04-29-2013 05:03 AM
I have an early regulator sitting in a box. PM me and I will make you a spiffy good deal I will try and remember to go look at it tonight to see if all the parts are there.
sundevil64 04-29-2013 05:09 AM
Joe,
PM sent.
Tobra 05-02-2013 01:07 PM
There is a window regulator "rebuild" kit for a Super Beetle that has those parts. I have two of those kits, but have not seen them for a while so I am keeping them. I got mine from Midamerica or someone like that. Maybe they just don't list it in the catalog
Dave at Pelican Parts 05-02-2013 04:49 PM
If you get the early one from Joe, you could have a whole bunch of the plastic bushings made up by a machinist. Might be able to recoup some of the cash outlay, or at the very least be able to help other early 914 owners who have a similar failure...
--DD
John Rogers 05-02-2013 09:38 PM
Back in the day when my daughter had her 914 2L and my ex-race car had doors with windows I needed several of these. I went to San Diego Plastics and bought some delrin rod (slightly harder than the nylon) close to the diameter of the largest part. I drilled the center hole on my drill press and then cut the steps with rasps and sandpaper. Once that was done I cut it off and made others the same way. I was about 1 1/2 hours total for 4 of them.
Michael7810 05-04-2013 02:22 PM
much as i hate to admit it, AA has them. Called window buttons. that's where I got mine.
TRE Cup 05-11-2013 04:56 PM
we made a few from abs plastic. its not that difficult using a file and a drill
red-beard 06-25-2013 11:41 AM
Los Panchos in Tijuana has 2 early doors from a 914/6, probably sitting on the roof...
