chrisreale's Avatar
Suspention query
Heres what I have: Koni Sport Yellows all around. 180# rear springs. I have the engine out, so when the old springs were on, the rear end was sitting high. Now that I wave the 180's on, the car sits about 9 inches off the ground (measured at both ends of the side valence). When the engine/tranny gets put back in, will the rear sit lower and the front end be higher?
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/
www.914club.com
Old 11-07-2002, 12:29 PM
korijo's Avatar
Chris,
You will probably have to lower the front a bit. I have Koni reds w/ 160 # in the rear with the 1.7L in. Sits lower in the back.
Maybe we could test on mine first, then yours when the motor is installed. Just a few turns on a couple bolts up front.
Just a thought.....
Korijo
Old 11-07-2002, 12:56 PM
