-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Some stupid questions from a really smart guy... (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/767613-some-stupid-questions-really-smart-guy.html)
frank 08-23-2013 11:23 PM
Some history first:
I have driven my 73 2.0 w/ dual Weber 44 IDF's less than 5k in 17 years and the guy I bought it from had it non-op for 10 years before I purchased it.
Around 2006 I sent my motor to Mike DiBernardi at Original Customs for a Raby 2056. I had the motor installed at Don Jackson Racing in Phoenix. I traveled about 6 days per week and sometimes longer which is why I didn't do much of my own work and didn't have time to drive it.
I believe it leaked from day 1. I didn't drive it enough and didn't want to spend money returning it to Mark or Don Jackson. I was told by a local shop that the leak appeared to be coming from the oil pump because it looked like the rebuilder didn't use a gasket, just a poor sealant job. I found last week however that the pushrod seals were to blame. I also replaced the oil pump gaskets for good measure.
My transaxle has leaks too. I have new bushings and seals in hand.
Fast forward: I don't travel anymore, I am living in California again, and I need to drive it now but not with leaks.
Last week I pulled the engine and transaxle out to deal with the leaks.
1st... DON'T ever use anything on the pushrod seals! What a pain in the @$$ to clean up after that stuff! It took longer to clean up the hardenned goop than it took to replace the seals... and it was a pain to pull the tubes out. Sealants harden and defeat the sealing quality of the o-rings! Let O-rings do what O-rings do! <end soap-box rant>
To my stupid questions:
1. My oil filler has nothing connected to the breather which has spewed oil everywhere. To where should a hose be connected? Should I install an oil catch? Which one?
2. What grade nuts and bolts should I use? I want to replace old nuts/bolts now that my motor is nice N' purdy. For the fan shroud and air diverters, I am using 8.8. Is this okay? Where should I be using 10.9?
3. Where can I get the heat exchanger nuts locally that have a 8mm 1.25 thread with a 10mm head? The 13 mm heads that were on mine are difficult to clear with a socket and I realized that they were not fully torqued for that reason.
4. I poured myself a Margarita when I started this post and now I am too numb to think of a 4th question... really.
5. Still nothing.
6. Does Extenze really work?
Thanks in advance for your feedback.
SiberianDVM 08-24-2013 04:13 AM
You lost me when you said you had a Raby. I'm in a jealousy inspired stupor.
Mike Bellis 08-24-2013 08:01 AM
1) Connect to the air cleaner
2) 8.8 are fine
3) try Bolt Depot - Nuts and Bolts, Screws and Fasteners online
4) Try Avion Tequilla
5) Yes
6) I hope so.
frank 08-24-2013 08:58 AM
Connect to the air cleaner? You mean one of the air filters? There is no provision on the air filters so do I need to modify the covers or filter element?
Jim Dorociak 08-24-2013 09:44 AM
Sorry Frank someone has to say it -- pictures please of your car. It sounds like a really interesting car and your history with it. Some of us only have the dreams of our 914s ever being completed much less running. You can not imagine how inspiring it is to see nice 914s. jim
frank 08-24-2013 03:02 PM
Jim... trust me, it's not as nice as I unintentionally made it sound here. It has left me stranded more times than I care to count but at each incident I have been able to correct the problem. It's the least desirable method for diagnosing an issue albeit the most common. ;)
I will post some pics though.
Mike Bellis 08-24-2013 06:38 PM
Yes. It is an early PVC system. You can get an adapter at the parts store. You drill a hole, pop the adapter in and connect the hose.
Dave at Pelican Parts 08-25-2013 10:53 AM
With a carb conversion, you're just likely to spit oil into the intake if you plumb that PCV line to an air cleaner. Better to use a "breather box" or catch bottle of some type. I do not know which are better. You also want to tie in the lines from the tubes that go into the rocker boxes, or they'll leak oil as well.
For holding non-stressed parts, practically any grade hardware is good enough. 8.8 is just fine for most applications on the car.
I don't know of any heat exchanger nuts that have a 10mm head. We carry ones with a 12mm head, which is a little easier to find room for than the stock 13mm head. Also, using a 1/4" drive socket can help; those tend to have thinner walls than the standard 3/8" drive ones.
--DD
lorenzoscribe 08-25-2013 12:51 PM
Breather
I made a catch can out of an aluminum water bottle that came with a bracket to mount to a bicycle frame. Close out shop for like $5.00. I cut the handle off the lid, drilled a hole in the middle of it and mounted a breather in the hole. The breather element I bought at Pep Boys designed for a small block Chevy. Look in the bling aisle.
From there I drilled a hole near the top of the bottle and put a white plastic 90 degree fitting that secures on the inside of the bottle. I bought that at Lowes.
After mounting the bracket to the firewall, I snapped in the bottle and connected it to the oil breather with a piece of clear hose. Works great. Although with the paranoia in California, I'd check to see if something like that is legal.
Larry Steckel
frank 08-25-2013 10:51 PM
Some photo's as promised:
Motor & Transaxle without carbs - Front
http://i169.photobucket.com/albums/u...5_110421-1.jpg
Motor & Transaxle without carbs - Side
http://i169.photobucket.com/albums/u...5_110344-1.jpg
Miscellaneous:
http://i169.photobucket.com/albums/u...8_180718-1.jpg
http://i169.photobucket.com/albums/u...8_180733-1.jpg
http://i169.photobucket.com/albums/u...805_133205.jpg
Interior - Double-DIN Custom Center Console:
http://i169.photobucket.com/albums/u...4/DSC_8952.jpg
http://i169.photobucket.com/albums/u...4/DSC_8945.jpg
frank 08-25-2013 11:41 PM
Thanks everyone for all the input... I will have to come back to the Oil Catch question during the carb rebuilds.
Can you point me to the rocker boxes? I may not be clear on that. Also, my carbs are connected to eachother via a hose near the base. Is this correct?
I will revisit the carb setup and post pics once I have the motor and carbs in. Shoud be in the next couple days.
Dave at Pelican Parts 08-26-2013 05:50 AM
Rocker box == where the rocker arms live, the area you see when you take the valve cover off. There should be a tube sticking up out of there on each head, unless they have been plugged or are 70-71 or 75-76 heads.
The hose near the base is probably for balancing the pressures in the manifolds. It isn't required, but can help smooth out the pulses in the intake a bit.
--DD
frank 08-26-2013 08:30 AM
Thanks Dave... I wanted to ensure we were talking about the heads since mine have no ports... apparently plugged up.
I did some research on the oil catch. It's a very simple system: oil vapor / mist in, condensed, collected, and cleaner air back out. The issue still exits as to where to connect the exhaust hose from the oil catch. I guess I will look for something that has an air cleaner / filter as the exhaust instead of an outlet for a hose.
Tip: The oil catches come in all sizes and prices. Get one with a baffle. The baffle will give oil vapor and mist something to which it can stick. Otherwise the mist will just pass through the can's outlet. I reqd that you can use steel wool in the cheaper cans without baffles but I would advise against it if you are venting the catch back to the intake because some wool could break loose and damage your motor. I found some baffled oip catches between $15 and $50 that I would trust.
frank 08-29-2013 07:09 PM
Does anyone know what the little plastic screw is for at the front of the impeller housing? Just curious. If you are facing the front of the motor there is a little white plastic screw that goes into a threaded hole near the top left of the housing.
frank 08-29-2013 09:37 PM
I keep forgetting to post this question so here it is now...
I noticed that the bellows is missing from my dual carbed motor. The flaps are always in the open position as a result. My motor does neecdto warm up for quite some time before it starts running right but I always thought it was just a chracteristic of the era's cars.
Is the bellows typically removed on carbed motors? Should a I replace it? If I need to replace it does anyone know what VW part x-references with it? I would also neecdthe linkage.
BTW... what I believed would be a simple 2 day effort to remove the motor and replace the push rod and oil pump seals has turned into a full-blown motor and engine bay dress-up.
Since my first post I have:
- Replaced the push-rod tube seals
- Learned how to adjust the valves and applied my learnings
- Replaced the oil pump gaskets
- Replaced all slotted cheesehead screws with allen cheeseheads in engine tin and exhaust
- Pressure washed and painted the motor & transaxle
- Cleaned and painted the engine bay.
- Repaired a broken weld on the muffler heat shield
- Undercoated the rear
- Painted the exhaust silver (Will help me find leaks in the future)
- Refurbished the relayboard
- Rebuilt both carbs
- Disassembled, painted, and reassembled just about every part I touched during this process.
Tomorrow I am replacing the driver-side rear wheel bearing. All the others were replaced about 2k miles ago.
I think that once the bearing is in I can put the motor back in.
I have all new shift bushings in hand to replace in the process.
I believe I have all new heater hoses that will help me finally get some heat in there.
I sure hope I remember how it all goes back together and that my valves don't get ruined when I start her up.
frank 08-29-2013 09:42 PM
Heat exchanger question:
My heat exchangers have gaps at the ends of the chambers that feed hot air to the the cabin where air will obviously escape and possibly draw bad air. Are those gaps supposed to be sealed? I am thinking of using some Quick Steel to seal the gaps. Any thoughts?
Dave at Pelican Parts 08-30-2013 09:15 AM
It is best if you run the thermostat. It should help speed up your warm-up cycle at least a little.
Not sure exactly what you're talking about with the heater. More description, or pictures?
--DD
frank 08-31-2013 08:40 PM
Okay, I will install a thermostat after this marathon of work is complete.
I will post some pics of the heat exchangers tomorrow while I work on replacing the rear whewl bearing.
I am going to try and put the drivetrain back in tomorrow as well.
Thanks again for the feedback.
frank 09-02-2013 09:16 AM
Some pics of the gaps in the heat exchanger warm air chambers:
http://i169.photobucket.com/albums/u...901_192221.jpg
http://i169.photobucket.com/albums/u...901_192235.jpg
http://i169.photobucket.com/albums/u...901_192244.jpg
Should I seal these up?
frank 09-16-2013 09:46 AM
Well, I have so far replaced every seal that was leaking and all my shift bushings. I degreased, cleaned, and painted every part of the drive train except the carbs. I undercoated the rear and will complete the front soon enough.
As usual I have discovered opportunities to fix things I for which I had no intention.
I found that my rear caliper pistons were stuck. Only the inside pads had wear. The outside pads look brand new. So I will have to figure that situation out.
I installed some replacement interior pieces I had been storing. I replaced all the vinyl / pads around the windshield... no more cracks! :) and after about 4 or 5 years without visors... I will be able to drive it without my cap down to the top of my shades... although that's a good look for me. :)
The carbs are in and I gave my son the project of building an oil catch. When he was done he walked out of the house to show me and said "Dad, I think I just built a bong." So yeah, I just gave a 16 year old some self miss-guided inspiration.
http://i169.photobucket.com/albums/u...915_183808.jpg
I must have a wiring issue because I touched the hot cable from the starter to the + terminal of my battery and the starter kicked in. The solenoid however did not. I was just trying to test the rewiring of my horn so I didn't have everything yet connected. I will hopefully get the wiring sorted out too.
Mike Bellis 09-16-2013 12:16 PM
Send your calipers to PMB Performance and have them restored. They will be perfect! www.pmbperformance.com
frank 09-16-2013 12:56 PM
Does PMB do them for free because that's pretty much what my budget is right now. :)
I'll have to figure something out in the mean time and replace them / send them out later.
frank 10-02-2013 09:38 PM
I plugged up the gaps in my heat-exchangers with Quicksteel and the hope that it will lead to better heated air transfer to the cabin.
If you should do this yourself, you need to ensure the housing is in the stock position or it will not align to the mounting holes in the engine case. I somehow made it work as I wasn't too far off.
I also replaced the starter as the one I had was toast.
frank 11-26-2013 08:12 AM
Mike,
I did a significant amount of searching for brake options and there was nothing that compared to PMB.
My GF bought me their rebuild kit for my Birthday and it arrived yesterday. It looks like a lot of work but it is by far the best option aside from having PMB build them for me.
I am thinking about painting them but not sure yet or what color. They sure do look purdy as is though. :)
frank 12-16-2013 10:28 AM
Well, I finally got around to tearing down my rear brake calipers to start the U-Do-It rebuild from PMB.
It has actually been a fun project.
My pins are all mismatched and 1 has the wrong OD.
Does anyone know where I could get replacements? The only place I found was in Atlanta and they want over $13 plus shipping per pin.
I will check with PMB today.
Dave at Pelican Parts 12-16-2013 12:18 PM
One of the pins in each rear caliper is too fat. That was done on purpose, I think to make sure that the pads went in the correct way. Unfortunately, pads with one larger hole have been NLA for quite a few years, so the typical procedure is to drill the one hole larger.
I don't remember if the fatter pin goes in the upper or lower hole, but it should only fit in one.
PMB has everything, most especially a very thorough knowledge of these brakes. Eric shouldn't steer you wrong.
--DD
frank 12-23-2013 12:20 PM
Although the pins are mismatched, I do have an original top pin with the fat sections in the pin for each pad and another fat one but it's only fat where it seats into the caliper; the rest of the pin is thin so maybe it rattles when driving or shifts when braking. I ordered some new hardware for the front brakes but I will see if they fit in the rears when they arrive.
So... finally I finished the rebuild in 3 easy steps:
Step 1: Remove, disassemble, and organize
http://i169.photobucket.com/albums/u...213_195438.jpg
Step 2: Clean, Paint, Reassemble, and re-install
http://i169.photobucket.com/albums/u...222_142136.jpg
http://i169.photobucket.com/albums/u...222_145859.jpg
http://i169.photobucket.com/albums/u...222_150219.jpg
Step 3: Admire
http://i169.photobucket.com/albums/u...222_150752.jpg
http://i169.photobucket.com/albums/u...222_150826.jpg
http://i169.photobucket.com/albums/u...222_151028.jpg
http://i169.photobucket.com/albums/u...222_151033.jpg
Security system & quality inspector:
http://i169.photobucket.com/albums/u...2_150238-1.jpg
I was really on the fence about painting them. The PMB Performace U-DO-IT kit has a nice finish and I thought painting tiny calipers would be cheesy. I would also have to match the fronts but I ultimately convinced myself that it's just paint and they can be stripped pretty simply. Once I decided to move forward with painting I was on the fence about the color Black?; Why bother, they can't be seen... but having a gloss finish will keep them clean... and maybe they can be seen particularly if I put red Porsche lettering on them... but there isn't much real estate for that. Body color?; What if the color doesn't match... why illuminate such small calipers? Screw it... now is the time to paint while all the rubber is out, I don't have to hassle with masking, and since they are disassembled it will come out looking clean with no overspray.
I am pretty happy about how they turned out but now I need to paint the fronts too.
I still need to purchase and install pads... the ones I purchased at my FLAPS had a little metal shim to the sides of the backs that would have caused them to shift when the caliper pushed against it. I will have to order some from our host.
GRM1964 12-27-2013 01:14 PM
Looks nice
Nostril Cheese 12-29-2013 04:32 PM
You can use a small bit of Curil T on the bores. This will guarantee they will never leak.
frank 12-30-2013 10:38 AM
I think I just may try Curil T as it's high-heat and doesn't harden... I think after installing my o-rings I may have a leak on one or two of the tubes.
