914 914 oil recommendation, brand, viscosity etc
need some advise, 1975 914 2.0l need a oil recommendation, brand, viscosity etc, also how many quarts do they hold with a new filter?. Thanks
Old 08-09-2013, 05:03 PM
914 Geek
Brad Penn 20/50, 4 quarts with filter. (More or less. Put in 3 1/2, run it a bit, then measure.)
Others have their own favorites. It's probably a good idea to get one with higher levels of ZDDP than current standards allow. The "flat tappets" have a better chance of not wearing the camshaft out that way.
--DD
Old 08-09-2013, 05:19 PM
can't find that local, anything close in a name brand, changing the oil tomorrow
Old 08-09-2013, 05:34 PM
935Sculpter
i have used Castrol 20W-50 non sythetic here in TX where its over 100 alot!
Depending on the temps where you live, you can choose the proper grade.. just don't get synthetic. when it gets hot (while running) the synthetic stuff seems to find ways to seep out and leak a little.
Good luck.
1972 911/935 Dp
1974 914 2.0
Old 08-10-2013, 07:37 AM
914 Geek
Valvoline VR-1 Racing oil in 20/50. Make sure you get the "not approved for street use", the one without the SAE roundel on it. That's the one that has the high ZDDP levels.
I wouldn't use a current formulation of Castrol, myself, unless they start making a high ZDDP oil.
--DD
Old 08-10-2013, 08:55 AM
Originally Posted by dave at pelican parts View Post
valvoline vr-1 racing oil in 20/50. Make sure you get the "not approved for street use", the one without the sae roundel on it. That's the one that has the high zddp levels.
I wouldn't use a current formulation of castrol, myself, unless they start making a high zddp oil.
--dd
x 2
Lucky owner of a couple of 911’s and a 924
Old 08-23-2013, 08:30 PM
