-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Finally in primer! (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/77312-finally-primer.html)
1bad914 08-12-2002 04:51 PM
Finally in primer!
The 74 is finally in primer. Visit the the 914 link in my signature to see the latest. More to come.
Randy
derek_sf 08-12-2002 05:09 PM
looks good! you and I are doing the same thing right now, but you're ahead of me! did you use epoxy primer? also, check out the links for the large version of the primer pics (they don't work).
1bad914 08-12-2002 05:29 PM
Thanks, it is repaired!
bludden 08-12-2002 06:01 PM
neat...
If it comes out as well as the Ghia, I predict sweetness!
3D914 08-13-2002 12:23 PM
Randy & Derek,
I'm impressed. I've only started the tear-down of my Signal Orange 2.0L, so I'm not ready for all the bodywork stuff, but I'd sure like to converse with someone who's been-there-done-that.
I keep getting side-tracked with the daily-driver. Gotta pull the engine again - rings have moved and its blowing past them.
I'd also like to hear about your portable paint booth. Did you use this to do the primer? I've thought about how I could quarantine part of my garage for this purpose, but haven't developed any plans yet. Plus I need to hide what I'm doing from the neighbors - sh#%@t - they're likely to have me arrested for exposing the neighborhood to dangerous chemicals!!!
Enjoy!
derek_sf 08-13-2002 07:03 PM
gerard,
spend some time reading the forums at http://www.autobodystore.com/cgi-bin/config.pl?index
you will find out so much information fast! it is a very active forum with tons of info daily. the owner (Len) will even answer your questions. he has a spray painting 101 instructional video he made, which is very good! he is working on part 2 now, which will be on bodywork I believe.
