-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   valve adjustment on the 1.7 and 1.8 need only be done every 6,000 miles (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/783875-valve-adjustment-1-7-1-8-need-only-done-every-6-000-miles.html)
RichW (guest) 11-25-2013 06:14 PM
One other point, I don't believe was mentioned -
as I recall, valve adjustment on the 1.7 and 1.8
need only be done every 6,000 miles, whereas on
the 2.0 the requirement is every 3,000 - please confirm?
Thanks!
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 11-25-2013 06:14 PM
I thought it was 12,000.
I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick
Dave at Pelican Parts 11-25-2013 09:55 PM
It depends on who you ask... The factory workshop manual recommends checking the valve adjustment every 5,000 miles for 1972+ four-cylinder 914s, which is the same as the oil change interval that they recommend.
I prefer to change oil every 3000 miles, and adjust my valves every other oil change--so 6000 miles.
--DD
