engine mounts
i was thinking about putting solid aluminum engine mounts in place of the rubber ones.does anyone know if that will damage anything or would it be ok to do that?
shawn
Old 08-30-2002, 09:37 PM
Ron Meier's Avatar
Solid mounts are great for racing, but in a street car:
1. transmits engine/transmission noise to the body and to your ears.
2. Possibility of cracking the engine case mounts or trans mounting ears from transmisssion of vibrations/shock to the case(s) from the mounts.
"Inventor - Blue Flame 914 Seat Heater"
"Yellow Rusty Cars Are Faster"
_____________________________
'70 2.5 (I'll never finish it - Somewhere over the rainbow.....,)
'73 2.0 (Just Not The Same)
'74 2.0 (Heartless & Lungless)
Old 08-31-2002, 06:33 AM
thanks for the warning
shawn
Old 08-31-2002, 12:11 PM
Stay away from my Member
campbellcj's Avatar
Even a lot of racers use the "Club Sport" (911) style engine mounts. The solid trans mounts are fine if you don't mind the vibrations/noise but solid engine mounts are kind of over the top.
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 08-31-2002, 12:23 PM
John Rogers's Avatar
On both our 914s I use solid trans mounts and stock front mounts. The tranny needs to be fairly solid for better shifting and the front mounts will absorb vibration well. Good luck.
Old 08-31-2002, 04:26 PM
Bruce Allert's Avatar
Speakin' of engine mounts, if my engine jumps when accelerating hard from a dead stop is it both engine and tranny mounts that need replacing?
bruce
Sit'n here
Hav'n a beer.
Punkin's gone
(sniff)
Gotta mow the Lawn...
Old 08-31-2002, 06:32 PM
Ron Meier's Avatar
Under hard acceleration, the engine tries to twist itself around and flip like a pancake (kinda). I would suspect:
1. loose bolts
2. Engine rubber mounts separated. I believe it would be the left one, facing the car from the front.
The rear is pretty solid when the bolts are tight. Maybe the rubber portion had deteroiated though.
Old 08-31-2002, 08:04 PM
914 Geek
Engine mounts, all the way. Could be the bolts in the brackets for the mounts coming out. BTDT on both of those... You will also notice that, under hard braking, the gear shift lever moves on its own quite a bit.
--DD
Old 08-31-2002, 08:52 PM
