How to ID Weber Carbs?
I have a set of Weber 2 barrel carbs. I can't find any obvious ID numbers. I am pretty sure they are IDF's based on pictures in the Haynes Weber Manual. How can I determine if they are 40's or 44's? Do the numbers refer to venturi/throat diameter in mm? Are there numbers on the body somewhere? I have bifocals but haven't tried a magnifying glass!
Old 09-12-2002, 09:16 PM
roadtrp204's Avatar
The numbers are stamped on the mounting flange, I believe oposite of the side with the idle adjustment and air compensation screws. 40 or 44 refers to the diameter of the throat in millimeters. The venturis are removable and come in different sizes, there is a number cast into the top side to denote size.
Chris
75 914 2.0L
Old 09-12-2002, 09:49 PM
jim, with 2 6's what are you doing w/ 2 barrel webers? did you get another car? the chrome's are crappy. good for roller wheels only, sorry about no reply.
kevin
Old 09-14-2002, 05:52 AM
