Cracked 1.8 Case? or Casting Line?
1974 914 1.8 case. Looks like a crack between lifter bores. No cracks in the lifter bores. Is this a known problem and can it be fixed by welding? (Its the case that has the oil cooler on it). I know the pics are not the greatest.
Sorry I don't have a case apart to check but it looks like a casting flash,if there no cracking in the lifter bore I wouldn't worry,you could always buy a crack test kit to confirm it to be on the safe side.
If it was a vw type one case I would be more cautious,I used to always crack test them before they went to the engine shop for a linebore,the T4 case is way stronger besides.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
Rookie
It's hard to see, but it looks like a crack to me. Too jagged to be casting flash.
Also, is it just between those two? If it were a split in the casting it is likely that the casting would be split between all lifter bores, not just that set. |
I would suggest finding a place to do a dye penetrant test on the are in question. It should be smoothed as best as possible and fully degreased to check for a crack. If the crack goes into the case internals it may not be worth saving as welding a case would involve heat treating and stress relieving along with the welding.
