Certified Porsche addict
The Glademister's Avatar
Square sway bar into round bushing?
So I've got the OEM front sway bar cleaned up, drop link bushings replaced and ready to install with Weltmeister Factory Performance Sway Bar Bushing PB-006. That bushing is a harder material than I've worked with before and I don't see how that's going to be pushed over those large square ends on the bar. Anybody got a tip?
Tennessee Region SCCA & PCA
Current projects - '87 944 Turbo, '87 924S, '82 931, '10 Boxster (the girlfriend)
Past projects - '83 944, '02 Boxster (x2), '99 Boxster, '14 Cayman,'72 Opel GT, '75 280Z, '90 300ZX, '87 944S, '87 944 Turbo, '88 924S (x2), '07 Cayman S, '73 914, '88 MR2 AW11
Old 05-07-2014, 07:12 PM
Push the bushing on the shaft before you install the caps. Significant force may be required, even if you use a good silicone paste lubricant.
The Cap'n
Old 05-07-2014, 07:45 PM
Resident Electrician
Mike Bellis's Avatar
Boil the bushings in water. Take the pan off the stove and into the garage. The water will soften them up for install.
Current Project: 73 914, 1.8t, ~300hp, 930 Brakes, Roll Cage
Past Projects:
69 911, converted to C2 wide body cabriolet 3.2L
72 914, Ford 5.0L V8 EFI
Old 05-07-2014, 09:14 PM
Thanks gents! I suspected boiling would soften the bushing. A little dish soap might help lubricate also.
Old 05-08-2014, 04:21 AM
You are going to want to grease with Lithium or something similar. Fitting with grease zirk will go along way to keep that bar from sticking.
Old 05-08-2014, 08:58 AM
