what R they worth
,...1.8 engine not running yet,..and the 5 spd trany....from a 74' Thanks
Old 04-27-2014, 06:31 PM
ASE Master Tech - 35 yrs
larrym's Avatar
worth the price of metal at the junkyard unless you can verify the condition as running, AND give us leakdown, compression and running oil psi
- at Pick-n-Pull it's worth about $200 and take your chances
the only way you can verify Trans condition is to put in in a car & drive it - unless the P.O. will testify in writing that it was working fine & no problems
the labor involved in checking out each item to find out if it is usable is substantial - unless you are just into this as a hobby and your time has no value
at $100/hr shop rate it eats up our "investment" real fast -
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 05-10-2014, 08:21 PM
914 Geek
Might be $150 each. Depends on a whole lot of things. They're basically cores, though, and worth whatever you can get for them as cores. I think Doc E is looking for 914 trans cores, so you might see what he thinks they're worth.
The engine could be worth as little as "Get it the heck out of here!". If it runs, it's worth more.
--DD
Old 05-10-2014, 09:38 PM
Resident Electrician
Mike Bellis's Avatar
What are they worth to you or me???
Current Project: 73 914, 1.8t, ~300hp, 930 Brakes, Roll Cage
Past Projects:
69 911, converted to C2 wide body cabriolet 3.2L
72 914, Ford 5.0L V8 EFI
Old 05-10-2014, 10:58 PM
