Preparation for Starting Rebuilt Engine
Hi all - Upon further search I have found the info I need.
Old 07-12-2014, 01:16 PM
Resident Electrician
Mike Bellis's Avatar
If it has been sitting for that long, I would pull the plugs and use the starter to prime the system. Pulling the plugs will take the compression load off the bearings while you spin the motor. Once you see the oil light tun off, put the plugs in and see if it will run.
Current Project: 73 914, 1.8t, ~300hp, 930 Brakes, Roll Cage
Past Projects:
69 911, converted to C2 wide body cabriolet 3.2L
72 914, Ford 5.0L V8 EFI
Old 07-13-2014, 07:49 AM
Thanks for the tip Mike.
Old 07-13-2014, 02:04 PM
