Drop 914-6 eng. to do valve adjustment?
I'm debating on having a large RAT motor built or going for 911 six cylinder conversion. And was wondering if you had to drop the six every time to do a valve adjustment. Plus you have to check the valve timing (cam sprockets) at the same time, right? I'm just looking at the Pros & cons of 4 cyl. vs. 6 cyl. Thanks for any info or input.
Ralph Gosnell 74 2.0 Slooooowly working on |
Assuming you have the 930 lower valve covers, and some of the Alum metal has been removed from them, you can remove adj the valves w/o taking the motor out.
The cam timing is done only when you have had to remove the camshafts from the engine for some reason.
--DD |
Grinding or sanding off the tops of the "ribs" (just on the top rear corner on each cover, actually) on the lower valve covers (assuming they are the "turbo" aka 930 covers) will give you the clearance you need to get the lower covers off without otherwise disturbing the engine. Pretty standard practice for sixes in teeners, which I learned only recently.
ALSO, when you're building your six, keep in mind you will be wanting to get at the upper valve covers and what's under them, so route your hoses, fuel filters, wiring, etc etc accordingly. |
I'm particularly glad that the fan rotates in the direction it does, since I stuck my hand in there when I got distracted while setting the timing -- no blood, no foul -- just glad it was at idle and not 3k or 6k rpm! Scott 74 914-6 2.7 |
I know which one I would use...Thats for sure!! :p
| All times are GMT -8. The time now is 11:37 PM. |
