bfrenz's Avatar
Front a-arm suspension bushing not rubber
Pick these up at a shop. CAn someone tell me if I should use them on my 914-6 or should they be just used on a "racecar". Would these produce less binding compared to stock. I dont know anything about these so any info would help.
1973 914-6 3.2 Motronic
Old 10-04-2002, 10:38 AM
those "look" like a set i put on my 72 long time ago. harsh,harsh,harsh. they started squeeking and eventually bound up even though i put a liberal amount of teflon grease on them. it was like i had solid pieces of steel instead of struts. for a daily driver on less than brand new asphalt not alot of fun. if you want to feel every expansion joint and pebble tear your front end off and put them on.
kevin
Old 10-05-2002, 04:29 AM
bfrenz's Avatar
Thanks Kevin, thats the answer I was looking for I guess I won't be keeping these as my car will be mostly street.
Old 10-05-2002, 09:02 AM
