-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Removing body from subframe (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/842842-removing-body-subframe.html)
Cairo94507 01-15-2015 06:31 AM
ggenovez - you are definitely on the right track in your thinking. Before you start your journey down this long, winding, slippery slope, I would recommend you spend some significant time checking the build thread in this forum as well as checking out 914World.com. Between the two you will get a full understanding of the undertaking required to handle one of these projects. Of course, posting up a lot of high-res photos showing the entire car, inside and out, top and bottom, will result in some excellent suggestions and advice from the many very talented people on these sites. Additionally, you may want to post the city/state/country in which you live in your signature to possibly locate some local experts to assist you. Just some thoughts as so many of these projects are started and abandoned when the work exceeds the depth of the owner's abilities. Good luck, these are great cars to save.
Racerbvd 01-16-2015 03:08 PM
Here is mine on a rotisory.
http://forums.pelicanparts.com/uploa...1421449712.jpg
http://forums.pelicanparts.com/uploa...1421449424.jpg
http://forums.pelicanparts.com/uploa...1421449442.jpg
http://forums.pelicanparts.com/uploa...1421449451.jpg
http://forums.pelicanparts.com/uploa...1421449469.jpg
http://forums.pelicanparts.com/uploa...1421449484.jpg
http://forums.pelicanparts.com/uploa...1421449493.jpg
http://forums.pelicanparts.com/uploa...1421449503.jpg
hardflex 01-18-2015 07:10 AM
Claus, how did that work out for you? Project done? I have two cars that need longitudinal work to make the doors fit right, so something like that could be very useful.
Racerbvd 01-18-2015 07:16 AM
I have a wooden one a buddy built, has PVC on countersunk holes to mate to the factory points on the 914 chassishttp://forums.pelicanparts.com/uploa...1421594166.jpg
http://forums.pelicanparts.com/uploa...1421594180.jpg
http://forums.pelicanparts.com/uploa...1421594190.jpg
hardflex 01-18-2015 07:50 AM
and the PVC provides the proper alignment distance, is that right.
That sounds perfect. Any more pics of it seperately?
Your Blue car looks Beautiful, by the way !
ClausGraf 01-19-2015 04:45 AM
It is working fine. This set up will allow me to rebuild the longs while keeping everything in alignment. I decide to go this route because:
1. The car was not rigid enough to go on a rotisserie.
2. I don't have the space to take it all apart.
3. Once the longs, floor and hell hole are repaired I will build a rotisserie to flip the car on its side finish the bottom work.
Racerbvd 01-22-2015 02:02 PM
Correct, will have to dig up pix, but it is going in for paint next (but not the extreme as the Blue Six) so I can get more pix then.
Thanks, looking forward to the "Six" being finished, hopefully in time for Parade of this year.
