911buff
Supercharging a 914
Just daydreaming here but has anyone ever attempted to affix a Judson supercharger to a 914? Or any type of supercharger for that matter? Seems like it could be installed where the AC compressor goes. The intake runner would rather long, granted. But would that be a huge issue. Again, just daydreaming...I still have a motor to rebuild. I guess I should get off of the internet and get back to the garage!
Hell Belcho
Subaru. Cheaper, simpler, more fun
Saved by the buoyancy of citrus. |
911buff
Could be. However, if I wanted a water cooled engine in a two seat Porsche, I would break down and buy a Boxster. Not what I want! I want to play around and put a supercharger on a type IV. Call me crazy if you want. Again, I was more daydreaming about possibilities. Just wondered if anyone had ever tried.
The biggest problem will be the drive.
The Cap'n |
If you have a 914 and want to do "mechanical" things to it, there are several choices:
- Leave it stock as you'll have enough things to go bad to keep you busy. - Make the type 4 bigger, $$$$$$ but lots of fun but $$$$$$$. - Convert to a six, $$$$$ but it will last much longer. - Add a turbo to the stock sized type 4 and many people have done that, $$$$$. - Put in another engine such as Subaru or a Chevy V8, $$$$$$$$. In all cases except #1 you will need extras such as suspension, transmission work, limited slip, bigger brakes, oil/water cooling systems, etc, etc, etc. I'd say keep an eye on Samba.com and buy something already done. |
Not even worth going there,you could build a ''full on'' T4 that would make the same power without the hassle of what you are planning,sorry not worth the load on your wallet.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
thotdoc
Type 4 engine mods
If turboing it appeals, call CB Performance in Farmersville, CA for complete turbo kits with everything well worked out.
Have fun. I built a 2.0 Type 4 for GT-3 SCCA, ran to 8500 RPM. Always wanted to turbo it..after lowering the compression from 12.5 to 1, or course. |
nein14,
What are you doing? How dare you post a picture like that without giving us any details. C'mon, spit it out Is this a custom package or did you buy it off the shelf?That's a sight of pure beauty. Thanks for sharing. |
