I got a big question on our 914-6, on the bottom, mine has been painted a different color (from the factory) and undercoated
![]() My paint guy says that he finds no traces of Blue on the bottom and that the color & under coating appear to have been applied from the factory.. , ![]() ![]() ![]() ![]() This is a Concours Restoration, so it has to be correct, so on one hand I'm thinking just Paint the bottom the matching Blue, but on the other hand, Porsche was also known to sometimes spray the bottoms with what ever was left in the Spray gun and I know of one collector who has a few 914-6s, like mine, both 70s and both OEM, yet one of his 1970s Six's has no coating; another '70 does ![]() I need to figure this out ASAP as the car is ready for Paint.. ![]()
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
>> 1970, 914-6, 3.6L (Conversion) >> 1970, 914-6, #374 (Original) >> 1975/73, 914 Limo (Custom) |
I think because it being metallic 2 stage in 1970 they didn't spray the chassis 100% like they did in later years, Like Andy say there is usaully the grey and then body color and then the black light pebble black undercoat, The dealer sprayed undercoat is heavy and globby.
All the non metalic -6's I have delt with are sprayed 99% over the beige, and then have the black pebbly undercoat on top. Later cars are painted 100% color and then undercoated and some not. Just my observations Your floor pan black pebble undercoat is like the many -6's I have owned. |
![]() Quote:
![]() So looks like we will go with a shiny, bottom...
Either John Paterak or Alan Caldwell will know the definitive answer. I know a one owner 72 -6 in Bahia Red that had the black undercoat over the red finish. It has the standard tan "seam sealer" undcoat under that.
Welcome to Concours.
![]() When the time came for the results and we looked over our judging sheets, the guy was able to convince the rest of the judges that the wheels were incorrect and we were docked a s&it load of points for it. It turned out that this is very common. Unless you protest, it's moot. I found that the winning cars were always owned by people who either knew the judges, were judges themselves, or were having their hands held by guys who had restored the cars and been through it before. You got a love it. No, I'm not bitter. I restored a car that placed 2nd in a parade and I did it myself! Everyone else we met "wrote a check". A lot of the judges were a bit shocked at the fact that we had done it ourselves. Almost to the point of disbelief. I just think it was sort of comical. Your car is a perfect example of the controversy where the judges won't shutup and just agree to disagree and remove it from that section of the judging. Ran into the same issue on that 911. Factory had sprayed the newer undercoating on the underside of the hood. Judge argued that it should have been the "sand pebble" texture from early years, yet I'd see many other 68s with the same texture as mine with chassis numbers after mine. I refinished the hood. Trust me. It was original. Ken- Last edited by kenrinc; 07-21-2013 at 10:37 PM.. |
![]() And you are correct, and the saddest part is many of those "Judging" have no clue about the older cars, they only know what they have read in books and as you found out, the closest to being involved in restoring or preparing a older Porsche is writing a check. ![]()
Update$$$$$
![]() ![]() ![]() ![]() ![]() Wheel wells.. ![]() ![]() Rear trunk.. ![]() ![]() ![]()
Wow that is coming out very nice. Please keep 'em coming.
'71 914-6 #0372 '17 Macan GTS |
starting to look real nice, that color is great!
When you're doing a conversion, you don't need to worry about that so much! I completely stripped this tub and applied 3M (expensive) seam sealer with a nylon brush just about everywhere, then applied PPG DP (white) epoxy primer, surfacer, and Light Ivory DCC. A 993 engine is slated to go in it.
Current: 914/6 GT Conversion, Cayman Old: Many PCars + Formula Racecars |
I love seeing these tubs clean and restored, if the car is a 6 or a 4 makes no difference. Just love seeing them like new, or better, again.
Not a truer word spoken,and the comments from Ken are as true ,each to there own but when you get guys altering shut lines on doors to achive a fit better than the factory EVER did is beyond common sense and then judges don't mark down for it,they should.
Racerbvd nice work on this car that is a great colour ,tell them it was special order,they will hate that cause they most likely couldn't prove otherwise ![]()
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
![]() ![]() Roblav, My GT clone is like that, the car I wanted ![]() ![]() ![]() ![]() ![]() Here is the engine for the factory Six... ![]() ![]()
Looks great.
Who is doing your resto? I have a 70 six in Adriatic Blue. Not really my favorite color, but I am 90% sure I will stick with it. Presently thinking of contacting Scott B or using CPR. CC |
Progress!!!
Nice sheen... from a good gun and a good painter. But blue is easier to paint than white!
I had never done a 914 before (always early 911's), so maybe my comments here might be helpful: When I was putting mine back together, the cowl was too low, and the fan blower was a pain to get in and the paint got scratched a little. And be careful re-installing the front suspension cross tube and steering rack. Easy to scratch the paint there too. The engine lid, when installed, will spring up and hit the targa top when you pull the release. I keep a rag handy there in case I forget. The front hood springs can be a pain to install too. I used a welding rod through the spring end and pulled it with vice grips. These cars are a little funky compared to the 911, but the more I play with it the cooler I think it is.
Current: 914/6 GT Conversion, Cayman Old: Many PCars + Formula Racecars Last edited by roblav; 12-14-2014 at 07:32 PM.. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() And now the fun begins, but I need a new pair of rear shocks & OEM springs, correct for the Six of course..
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too Last edited by Racerbvd; 01-29-2015 at 03:16 PM.. |
