chrisreale's Avatar
Question Do you need spring compressors for 140# rear springs?
To install them, are spring compressors needed?
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/
www.914club.com
Old 10-22-2002, 02:44 PM
914 Geek
Depends on the free length of the spring. I forget what the max is for not needing the compressors...
I think most 140s do not need compressors to install. Mine did not.
Removing the old stock springs is safer if you use them. Some people who evidently can't spell "liability" will just tell you to take it all apart without even thinking about where the spring could launch the upper retainer, washer, nut, etc. If you do decide not to use spring compressors to take the old springs off, be careful what you point them at. It's no fun to go looking for the little bits that jumped across the garage and out of the door... And that's assuming they don't wind up bouncing off of you first.
--DD
Old 10-22-2002, 03:00 PM
chrisreale's Avatar
Yea, how would I explain to my girlfriend why my face is black and blue? "No it was NOT a bar fight...!"
www.914club.com
Old 10-22-2002, 04:16 PM
Zeke's Avatar
You might cop to the bar fight rather than admitting that your car hurt you.
Old 10-22-2002, 06:22 PM
3D914's Avatar
Chirs,
I go with Dave. I did my 165# springs with no special compressor. I was able to push a little to get the nut started, and worked it down from there. No brainer!
Regards,
Gerard
74-914 White - Soon to be a custom 3.2L Six 87-924S 2.5L Artic White - SOLD 74-914 2.0L Ravenna Green - SOLD
Old 10-23-2002, 12:43 PM
It's taking the old springs off that will bite you! Buy,borrowor steal some spring compressors. I got mine (china) for $8.00 at a flea market. good luck!
Duane
'03 M3 Coupe, '65 Mustang 2+2, '72 Cherokee 140
Old 10-23-2002, 01:13 PM
Not right in the head
nutzforporsche's Avatar
Send a message via Yahoo to nutzforporsche
On the subject of springs.....
How in the heck other than setting the spring height / tension do you adjust them? I know that inside the rear trunk there is the main keeper nut that holds them on, but there is this little adjuster sticking up. What does that puppy do?
Thanks All!
73' 2.0L Rayco Bodied Teener
Old 10-23-2002, 01:23 PM
Bilstien!
Bilstien shocks have seat adjustments on the bottom end of the shock. allowing you to adjust the seat pearch up or down by moving a c-clip. you must compress the spring to do this. Most shocks do not have this feature.
Duane
Old 10-23-2002, 01:30 PM
914 Geek
Some few shocks (mostly Konis) have an adjustment up on the top. It's for rebound damping, I think, though it might be compression damping.
Most shocks don't have this feature, even most Konis are adjusted by collapsing them all the way and turning. Thought the gas-filled ones don't take well to being bottomed out like that...
--DD
Old 10-23-2002, 02:21 PM
Thank you guys for the info. I learned lastnight that if the car is jacked up and the arms allowed to extend that the little knob at the top most certainly is a damper adjustment. I tried several turns in different directions and I noticed that it would sort of like increase or decrease the rebound pressure that it would take. Ok I found something else to fiddle with! I wonder if I can get a set with these adjusters to fit the Mrs hee hee. Back to reality I'm married for petes sake, we don't do that anymore lol. Anyways I'm certainly glad to know what they do, maybe now I can get some more defined handling in the curves.
Old 10-24-2002, 04:59 AM
Brad Roberts's Avatar
That's a major score for you.
Adjustable Koni's are EXPENSIVE.
B
Old 10-24-2002, 08:36 PM
chrisreale's Avatar
Dave or Brad or someone-
When you say that Koni's are adjusted by colapsing them, what reasons should they be adjusted? My new Koni sports are just as long as the KYB's thjey are replacing.
www.914club.com
Old 10-24-2002, 09:02 PM
914 Geek
Some of them (NOT the ones with the tab up top for the knob!) you can change the compression or rebound damping (again, I forget which) by pushing the rod all the way into the tube, and then turning it.
Generally you don't do this, unless you really really have to adjust the handling of your car. And in that case, you're much better off spending the money and getting the externally-adjustable Konis. Because it's a huge pain in the butt to have to take the strut apart just to adjust the stiffness of the shock.
--DD
Old 10-24-2002, 09:25 PM
