1.8 Litre L-Jet Wiring ?
I just acquired a 1975 1.8L 914 from of all places the junk yard. (Figured I was going to look at a parts car because it was turned in due to rust problems) The Saints were smiling that day, the rust was only in the left front pedal area. 78,000 miles Put air in 1 tire, battery in back and drove her home.
What I need is the wiring diagram for a 1975 L-Jetronic with the color code information for the wires from and to the relay board and on to the double relay. Not the function but the actual wiring, the L-Jet feeds power differently to the ECU, through a double relay near the battery. In the wire harness from the engine side, is a spare thin gauge yellow wire with a female spade connector on it waving around free. I would like to know where this is supposed to go.
Old 07-30-1999, 05:17 AM
914 Geek
The diagrams are available on this site. You can click on "electrical diagrams" under the 914 section on the main page, or you can use the link: http://www.pelicanparts.com/914/parts/Electrical/914_electric_74_AFC-B.jpg
The wire in question goes from the #2 pin in the four-pin connector (right-rear pin, left-rear connector) on the relay board to terminal 86a on the dual relay. Look for little numbers on the relay or on the relay's plug.
--DD
Old 07-30-1999, 10:26 AM
