Porsche 914 Oil Recommendation
I understand from my mechanic that I need to run a motor oil that contains Zinc. What are your recommendations for oil that I can typically purchase at a large box automotive store? Thanks
Old 09-12-2015, 05:52 PM
914 Geek
Motor oil is one of those quasi-religious topics for gearheads. You'll find many opinions, and a fair number of people will defend their choices vigorously.
Valvoline VR1 racing oil (technically not for road use) has lots of fans. It has elevated zinc levels.
Brad Penn 20-50 I think still has the elevated zinc levels.
Joe Gibbs makes an oil that does as well. I believe that was developed in partnership with Jake Raby, noted Type IV engine builder.
Some like the Mobil-1 motorcycle oil. I'm not sure if all of those have elevated zinc levels or not.
We used to use diesel oils, but they were required to cut down on the Zn levels in recent years as well.
--DD
Old 09-12-2015, 09:05 PM
rbp rbp is offline
rbp's Avatar
I use Swepco 306 or Brad Penn both have very high Z & P levels which are a requirement for solid valve train.
Old 09-13-2015, 08:38 AM
Any thoughts on Shell Rotella?
Old 09-13-2015, 12:23 PM
914 Geek
It no longer has enough ZDDP for me to be comfortable using it. (That is one of the diesel oils I referred to.)
--DD
Old 09-13-2015, 07:18 PM
Mats's Avatar
Motul 300v had higher zinc content, not sure how it is now.
Old 09-13-2015, 09:11 PM
ASE Master Tech - 35 yrs
larrym's Avatar
Exclamation oil oil oil zddp oil oil oil ultimate-motor-oil-thread
if you did a search here - you would have found this
Ultimate Motor Oil Thread or Why we hate CJ4/SM oils
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 09-15-2015, 07:59 PM
