Tach wiring
Hey all, can anyone give me a simple version of the wiring on the back of my '74 1.8L tach? I have perfect ground, good bulbs. I checked continuity, fuses, relays, but referring to my wiring diagram which i am confused about, added to the fact that I'm a contractor, leads me to believe that I need advise. My tach is functioning, I had it tested, so which wire goes where? Thanks for any help!
Old 09-14-2016, 05:22 PM
Looking at the BACK of the tach, far right terminal is ground, center terminal is the signal coming from the engine and far left is +12V power when key is on. Hope this helps .. Bob
Old 09-14-2016, 06:54 PM
bulitt's Avatar
Not sure what year this pic is for but maybe it will help.
Old 09-27-2016, 05:34 PM
