-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   3.6 conversion question (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/87981-3-6-conversion-question.html)
chief914 11-18-2002 06:50 PM
I have aquestion on mounting my 3.6 engine. I'm planning on using a Rich Johnson provided engine mount and I'm questioning whether the stock 3.6 pulley arrangment will work with the mount, or do I have to convert to a single pulley system???? Also, I want to run a set of stock heat exchangers and have noticed that they will not fit without mods to the HEs. Has anyone run this setup?
One more question......I've seen a couple 3.6 installations where the intake was flipped to place the airflow sensor/K&N filter over top of the distributors. I would like to do the same to avoid cutting up my trunk bulkhead (plus it just looks really clean and trick). When I looked into this on my motor, it appears that the intake plenums (center sections) are linked together by a webbed support, which seems to prevent flipping of the intake. Are the folks doing this mod cutting apart this center section webbing or am I missing something??
Thanks in advance for any info you could provide!
jabb 11-18-2002 07:22 PM
I would ask Rich about the mount I know he modifies the mount for the 3.6 not sure what pulley will work he would be the best one to ask.
Dave at Pelican Parts 11-18-2002 07:52 PM
For some info on how one person did the job, see:
http://www.pelicanparts.com/MotorCity/siverson/914/36/index.html
--DD
