Auxiliary Air Regulator hose
Can anyone tell me what the hose that goes between the AAR and the intake air distributor looks like?
Mine was a short piece of hose with an ice-pick hole in it to accomodate a small vacuum line. However, because the AAR doesn't line up very well with the port on the intake, the previous owner left out the mounting screw nearest the passenger side. Plus the small vacuum line did not seal well.
I'd like to mount the thing correctly, but have no clue what the hose is supposed to look like.
1994 BMW 840Ci
1988 BMW 325i Cabrio
Old 11-20-2002, 05:40 PM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
Its just a short piece of hose no vacuum line should be icepicked into it. Sounds like a nice place for a big vacuum leak. What does the small hose plug into that was spliced into the large AAR hose?
Sounds like a DPO hack job to me to run the whats it or the defrombilator.....
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 11-20-2002, 05:51 PM
Bruce Allert's Avatar
On page 40 of the Haynes manual it shows a diagram of the hoses with the small hose your questioning. The short hose between the AAR and the intake air dist. has a small black plastic "Y" and this is where the small hose of the deceleration valve is connected. Here's a quote from Brad Anders.
Unless you're trying to pass smog, I'd suggest you simply remove the decel valve and cap the ports on the plennum and air box. It is only a secondary emissions control device, and is not essential for the car to run properly.
The hose between the air dist and the AAR is very short. I took Brads advice and my Calif. 1.7 (EB) runs great.
bruce
Sit'n here
Hav'n a beer.
Punkin's gone
(sniff)
Gotta mow the Lawn...
Old 11-20-2002, 06:25 PM
Bleyseng's Avatar
My 70 1.7 didnt have a decel valve so no tee.
I don't run the one on my 76 either...
Geoff
www.914Club.com
My Gallery Page
Old 11-20-2002, 06:52 PM
Ya... mine don't have one now either even tho I couldn't blow thru it I still took it off as an experiment. Glad I did. One more thing that can't go wrong!
bruce
Sit'n here
Hav'n a beer.
Punkin's gone
(sniff)
Old 11-20-2002, 07:00 PM
Yep... the small vacuum line goes from the ice pick hole to the decel valve. Thanks for the advice... it'll be coming off the car.
1994 BMW 840Ci
Old 11-21-2002, 03:50 AM
Hey Ian, ya got a great web site and a nice looking car. How's it running now?
bruce
Sit'n here
Hav'n a beer.
Punkin's gone
(sniff)
Old 11-22-2002, 06:45 AM
Thanks, Bruce!
The car looks nice from a distance thanks to a $100 paint job that the previous owner applied. It needs a complete restoration, which is what I'm going to do over the winter. I'll let you know next week how it's running. I should have the proper engine mounting hardware in place and for the first time be able to get it in 1st and reverse by the end of the weekend!
1994 BMW 840Ci
Old 11-22-2002, 07:46 AM
