Porsche 914 Window Sweeps or Window Squeege
I bought replacement rubber sweeps for the roll down windows on my my 914. They don't snap in, they need to slide into a channel in the area above the door handle which I am having difficulty doing. This there a lubricant that I can use that will not cause rust issues after the strip is properly inserted in the channel? Or is there another solution? Thanks.
Dish washing liquid and water is good,should just pop right in,you are talking about the outside scrappers right? mine are new but not a really tight fit in there.
Remember to cut them longer than they need to be as they do shrink a bit, mine were cut short bugger it.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
the end might be crimped a little try to wallow it out with an awl or something. also try pull it through rather than pushing. heating it will probrobly help it be pliable. make sure its not stretched when you finally do get in in. try and compress it as much as you can. definately cut it way long. dont use any petroleum based lubricants that hurt the rubber. i would think dish soap or even tire lube would be fine
82 SC , 72 914 |
