vanagon/ 914 2.0l 94mm cylinder...same?
Does anyone know if a 1980 vanagon 2.0l 94mm cylinder is the same as a stock 914 2.0l 94mm cylinder...? just the cylinder is in question...trying to find a fix to replace a single "bad" cylinder...
thanks. hey jim, depending on the answer I will call to hook up over the weekend...thanks
Scott 1982 911 SC 1962 sunroof bug 1991 WE Vanagon CARAT WRX conversion |
Yes, both cylinders share the same "039" part number....ensure the cylinder height is the same on both of them though.
Jake Raby Owner, Raby's Aircooled Technology www.aircooledtechnology.com www.massivetype4.com |
