-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Lowering question. (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/89539-lowering-question.html)
sasquatch 12-03-2002 09:06 AM
Lowering question.
I would like to get rid of the stock "nose-high" attitude of my 74 1.8. Do I just measure from the ground to the fender lip and make all four corners equal? Or do I use some other point on the car to measure from?
Sasquatch
Conrad W Peden 12-03-2002 09:32 AM
Personally, i use the center of my front tire to the fender lip then compare to the ground.
Seeing as you will be under there... I would make the front suspension cross bar level.
Too low you may need rack spacers.
Doug M 12-03-2002 09:44 AM
I use the seam on the flooor pan and a 4" piece of 2x4
tryan 12-03-2002 09:44 AM
the fender lips are different front to back. the front is easy to adjust, but to low and the handling ' goes away'.
3D914 12-03-2002 11:01 AM
I agree with Tryan,
Lowering too far and you'll degrade the steering/handling characteristics, unless you're doing more to the suspension. I'm actually going to raising mine about 3/4in, front & rear.
Also, I found the fender lips to be somewhat unreliable side-to-side, as there can be variations from assembly. So I started checking at the jack donuts (front & rear). Here you have to be careful too, to be sure they're not damaged/bent as it will affect your measurements. Be sure to cycle the suspension after adjustments before checking measurements.
Enjoy!
sasquatch 12-03-2002 01:03 PM
Thanks for all the good information. The jack donuts on my car are in pristine condition. I just want to get the car flat, then I can corner balance the car. I gotta put that $1200 set of corner scales to use somehow in the winter time. :D I ordered a new set of shocks all the way around, and I am going to get springs for the rear, probably the 140lb ones. I think I will wait untill then to set all the ride heights.
Sasquatch
