-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   front trunk jammed (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/89575-front-trunk-jammed.html)
tahoward 12-03-2002 01:25 PM
front trunk jammed
Apparently items packed in the front trunk shifted during shipping and now the trunk won't open. I'm guessing the front bumper has to come off, but then what? Any other thoughts? Thanks all.
odie 12-03-2002 01:32 PM
how about driving forward and reverse, hitting the brakes hard? maybe something will shift again.
douglas robbins 12-03-2002 01:32 PM
If it is jammed only from objects shifting in transit and not from a broken cable then you should be able to open it without lifting a wrench. Have a friend push down on the nose of the trunk while you pull on the release. That should give the locking mechanism enough room to work.
If that does not work then yes remove the bumper. Right in front of the lock is a small hole. Wag your flat head left to right in the hole to release the lock. Much easier than the rear trunk.
Douglas
JWest 12-03-2002 01:39 PM
Seen the new Volvo commercial with the pizza?:)
