totle's Avatar
911 ignition switch in 914
Hi,
Building a 914-6 GT replica.
Remember seeing projects where some installed a 911 ignition switch in a 914 to make it more like the 914-6
Anyone has a link for such tutorial/work ?
What parts needed ?
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 02-01-2016, 04:32 AM
I think you will need the 911 upper wheel assembly that bolts to the dash as it has the hole for the lock pin
Old 02-01-2016, 04:40 AM
budge96's Avatar
To make the conversion you need an entire upper 911 column plus the ignition switch and rear
switch electric connector..
GT2
RS 3.2
RSCS 3.8
R 2.5 Twin Plug
Old 02-03-2016, 12:37 PM
Go over to 914World. It has been covered. You need 69-73 911 column. Has to be cut and modified.
Old 02-04-2016, 05:57 PM
