-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Slight stutter when I am driving (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/90330-slight-stutter-when-i-am-driving.html)
chrisreale 12-09-2002 09:44 PM
Just noticed it today. I was going about 35-40mph. I was in 4th gear, about to move down to third, when i noticed a stutter. Felt like it was coming from the right side, maybe the rear. I was thinking it couyld be that I was getting my rpm's too low (I hadnt down shifted into third yet, and was only going 35). It doesn't happen when i am in third, or when I am speeding up, only at a consistant speed, around 35 0r 40, and the rpm's are around 2500 to 3000. Is this just the transmission saying it wants higher rpm's, or is this a rear wheekl bearing, cv joint...? thoughts appreciated.
Brad Roberts 12-09-2002 09:54 PM
Did it buck ??
Trigger points and/or pressure sensor can cause a bucking sensation.
B
todd914 12-09-2002 09:55 PM
35 mph in 4th. Most likely nothing. Keep driving it and if it does it again try and conduct some controlled experiments to see if it's a gear*rpm related issue or something more.
korijo 12-09-2002 10:06 PM
chris,
Do you still have the wrong MPS? Makes sense of Brads reply.
:D
chrisreale 12-09-2002 10:16 PM
Yea, i got a 1.7 MPS. I am waiting for Bleyseng to fix up one he is going to sell me (*hint..cough Geoff*hint). I didnt know that the MPS could do this. Lernt sumfin nu tuday
Bleyseng 12-09-2002 10:53 PM
I tested it in my car tonight, Chris and all is well.
Could be the TPS is mal-adjusted or old for that stutter at 2500-3000rpm.
Or what is the timing set at? Is the distributor new/rebuilt? A worn dist also will cause problems like this.
Geoff
