Question on 914 heads
Hello and i have a question on my 1.8 heads. Can someone please tell if if its the drive side or passenger that has a small theaded hole for the temps true sensor. Thanks in advance.
Old 02-21-2016, 02:41 PM
914 Geek
Passenger's side, when the engine is installed in a 914. (When the engine is installed in a rear-engine configuration, it is turned 180 degrees. But in a 914 the fan is forward and the flywheel is aft, so the Temp Sensor II or CHT is on the right-side head.)
--DD
Old 02-22-2016, 08:02 AM
Thank you!!
Thank you so much!!
Old 02-23-2016, 11:27 AM
