hargray2's Avatar
special tool?
Where do you get the wrench to hold the tab washers on the tops of the front strut towers?
Old 12-10-2002, 03:06 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Pipe wrench, available at most hardware and plumbing stores.
--DD
Old 12-10-2002, 03:12 PM
hargray2's Avatar
Just out of curiosity, isn't there a special tool for this? I think I remember seeing a wrench with a "tooth" on it to fit in the little notch on the washer. Oh yeah, what can you NOT do with a monkey wrench?
Old 12-10-2002, 05:25 PM
chrisreale's Avatar
I seem to recall seeing a special tool used in the Haynes book. That said, I used a pipe wrench and pb blaster.
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/
www.914club.com
Old 12-10-2002, 05:49 PM
Mike Ginter
gint's Avatar
Air hammer will also work well if you loosen the collar before taking the strut out.
Ginter's 914 stuff
Old 12-10-2002, 07:50 PM
Administrator
Yes, there is a special tool for this. You can probably find it at Baum Tools if you look. A pro Porsche mechanic or a dealer mechanic might use the proper tool. Just about everyone else uses a pipe wrench or an air chisel. (Hi, Brad!) I actually used a large pair of channel-locks because they were handy... But that required two hands to hold, so I had the buddy who was helping me swap the struts loosen the nut while I held the washer.
--DD
Old 12-11-2002, 10:11 AM
RustyWa's Avatar
If you have access to air tools..use an impact wrench. One quick flick of the switch and the nut will be off.
I don't have air, so went to the local tire shop and they loosened the nuts for free.
Eric
'75 914 2.0L - Sold!
Old 12-11-2002, 12:05 PM
