motor mounts
Can I change front motor mounts with motor in car . If so whats the best way
change the motor mounts
Is this a 4 cylinder configuration?
Also guessing that you are running sport mounts, like I was, and want to change back to solid mounts. Correct?
Randal |
Sport mounts
Sport mounts look like this:
Randal |
motor mount
75 1.8 it look like the og mounts that in it what mounts do you think are best this is just a daily driver stock
motor mounts
Someone like Dave Darling can correct me, but I thought the stock mounts were solid.
I've just changed back to solid mounts and once installed and tight don't need to be changed. So are you running sport mounts, like the picture or what?
Randal |
Administrator
Early four-cylinder cars (70-72) with the tail-shift transmission had solid mounts between the engine and the motor mount bar, while they had rubber mounts at the outboard ends of the motor mount bar. The picture above shows rubber outer mounts with a later side-shift engine bar, which from what I can tell does not work well. (Generally allows too much sag and movement in the motor's position.)
Later four-cylinder cars (73+) with the side-shift transmission had solid mounts outboard between the bar and the chassis. They had rubber mounts inboard between the engine and the mount bar. OP, which style of mounting do you have? They can all be replaced with the engine in the car, but access to some fasteners can be somewhat tricky. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Remove nuts on thru bolt on the bar. Lift engine slightly and support on a jack or some means to hold it in place. Remove the 4 motor mount fasteners (2 each side) with the 1/4 drove rachet if you can get it to fit or use a 13 mm wrench. Pull assembly free ... remove old motor mounts .. put new ones on ... installation is the reverse.
Ron Meier Backyard Shadetree Mechanic 1974 914/6 conversion with 2.7L (The Grey Ghost) 1973 Chalon with 2.4T MFI (Schlitzalom) All my 4 cylinders are gone ![]() |
motor mount
getting to top nuts on motor any trick to that.not much room from what I see
Administrator
For my 74, I removed the oil filter and reached in to them from the side. That was after removing the bar; the nuts on the bottom are not hard to remove.
I got a bunch of oil on my arm, but I did get the center mounts installed. I used a fine-tooth ratchet; a stubby ratchet might have helped also. One click at a time--it was pretty tedious. I snugged the nuts as well as I could with my fingers, which was much faster than using the socket the whole way. Is your car a 73+ one? --DD
Twink Driver
I made a plate to replace the small cross member that the engine bar is bolted.
motor mounts
75 1.8 what size is top nut
Administrator
Same size as the bottom one. They're both M8, which take a 13mm wrench.
Uh, that's for the ones near the center of the motor, not the ones on the outboard ends of the bar. Those are M10, and take either a 17mm or 19mm wrench. --DD
Thanks guy for all the will get to that this weekend
I did, not that tough.
Work to Live, don't live to work... |
For the 8 years of owning my 914 I used Plastic cutting board as engine mounts. 3 pieces of 3/8" polyethelene (sp) 2 1/2" dia and a 8mm hole drilled in the center. Through bolted and the motor never moved. Vibration was not much of an issue and I drove it everywhere. Rear trans mounts were also custom. Car always shifted great.
motor mounts
so what your saying is that 1.125 thick by 2.5 round how long is 8mm bolt
JWest makes a set of hard nylon front mounts for $30, if you want them pre-made. I don't know anything more about them or how they perform.
JWest Engineering |
MOTORMOUNT TORQUE??? I just did the sold rubber ones and when tightening the nuts, it seems like the rubber is just compressing???
Is there a proper torque? Thanks for the related Hijack |
Reviving an old thread, but I'm trying to confirm the bolt size for the fasteners that go through the middle of the outboard engine mounts. Everything I read says M10x85, but the fasteners I removed are (and need to be) about 100mm
I'm also not convinced a PO used the correct bolts. The rears (at the transmission) are 12mm, and the diameter of the insert in the engine mount is the same as the transmission mount...making me think I should be getting 12mmx100 for the front outboards? Thanks, Stephen |
Administrator
The PET (the factory parts manual) says that the early tailshift cars (70-72) used M10x90mm bolts. Those should be close to 100mm overall length, when you add the bolt head in. The 73+ motor mount bolts are M10x85mm.
The two big bolts for the transmission mounts are listed as M12x125mm. --DD
