elwood-914's Avatar
Question Replacing brake hoses
I am replacing the brake hoses with s.s. braided lines. How the heck do you undo the upper hose on the rear sets. I can't seem to get my wrenches up there. I just want to make sure I don't damage the tubing. Thanks
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 12-29-2002, 03:23 PM
You can remove the clip that holds it to the body. This should give you a little more room to get a good flare wrench on it I think it is a 17mm on the big end.
Old 12-29-2002, 04:32 PM
ruddyboys's Avatar
Be very carefull removing the steel lines, the flaring is usually stuck and the steel lines brake very easily
74 LE "Bumblebee"
03 Jetta Wagon
Old 12-29-2002, 05:03 PM
