midlifecrisis's Avatar
new ignition.....
i have a 1973 2.0L stock and have always hated gapping points, setting dwell.... etc. So I am open for upgrade suggestions and recommendations. Yep, I am lazy and would rather do this once ina while rather than with some frequency..... cuts into quality time with kids, wife and detailing!
Thanks,
Scott
Old 12-28-2002, 04:54 PM
John Rogers's Avatar
I have used Compufire units on both our 914s for years and NEVER had a problem. Remember to tell them which distributor you have as they have a couple of models. Good luck.
Old 12-28-2002, 05:38 PM
pertronix ignitor
Old 12-28-2002, 05:59 PM
DDS DDS is offline
I went for the Mallory distributor and their Hyfire 6 box, plus a new bosch blue coil. Expensive, but I'm hoping it will be worth it in my mildly hopped 2056cc. Haven't installed the motor yet, waiting for spring...
-- Dave
'73 914, 2056 GT/SC done!
'69 Lotus Europa S2 - under resto.
pics at
http://www.syer.net
Old 12-28-2002, 07:00 PM
pbanders's Avatar
Send a message via Yahoo to pbanders
Crane XR-3000 and one of their non-ballasted coils. Works great.
Old 12-28-2002, 08:29 PM
hardflex's Avatar
is a pertronix the same as a perlux? My 72 has a perlux, haven't had any problem except the rotor rubs on the unit some. I'm using it with a bosch coil, says 1.8 ohms of resistance. I'm a little worried it's too hot a spark, is that possible?
My 76 has an allison optical, I think they've become the crane xr700. It's been great too.
Both of em beat the heck out of adjusting the points and the timing routine. Set it- and forget it
PD
72 914 2056: 74 9146 2.2: 76 914 2.0
Old 12-28-2002, 08:30 PM
hardflex's Avatar
and while we are on the subject of ignitions, what kind of Spark plug wires would you recommend? Bosch, I presume? Mine are pretty stiff and brittle, need a new set soon/
PD
Old 12-28-2002, 08:44 PM
chrisreale's Avatar
PD
Personally Id stay away from the Bosch wires. Mine are new, and they are very loose on the dizzy cap, like they dont want to snap down right. But, they do work so far, but I am going to replace them soon with something better, like Fyrebraid(!) or those spendy wires that Ginter(i think it was him) posted awhile ago
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/
www.914club.com
Old 12-28-2002, 09:14 PM
I use the 8.5mm Accel universal big-block V8 set and put the ends on with the neat little tool they give with them. You end up with two sets if you buy them that way and the rubber seals do fit over the boots. Good luck.
Old 12-28-2002, 10:39 PM
DDS DDS is offline
Yup, the Accel V8 set per advice from John a long while ago. You can get new rubber seals cheap from a vw bug place, plop them in a cup of boiled water to make them pliable and they slide right on. I have four wires left for my next car.
-- Dave
pics at
http://www.syer.net
Old 12-29-2002, 06:03 AM
hardflex's Avatar
then i have a set for both cars, what a deal!
thanks guys
Old 12-29-2002, 06:37 AM
914 Geek
I'd be more inclined to use the Crane (they bought the design from Allison) optical one over the Pertronix (which used to be Perlux). The recent Pertronix seem to have spotty QC. Plus they evidently like to die if you leave the ignition on without the engine running (like to test something) unless you buy the new and more expensive "Pertronix 2"...
No experience with Compufire so far, but I haven't heard any complaints yet. Sounds like it might be similar to a Pertronix with better build quality.
--DD
Old 12-29-2002, 10:58 AM
