sacook's Avatar
Back to well of knowledge - electrical Prob
Okay another weekend of 914 work.
When I turn the ignition on I get a tic, tic, tic, from the relay turn signal/ emergency signal flasher unit (Identified as number 47 on schematic). The turn signals and flashers work normally and the tic is a little slower than the normal signal/flasher tic. Here’s another piece to the puzzle. When I was road testing my heater work from the weekend, the number 9 fuse fell out accidentally and all the gauges and generator light blinked or moved erratically. When I depressed the brake pedal all the gauges went dead and the generator light stayed on….
Any thoughts???
73 914 1.7
When I had my boat I used to throw 50 dollar bill at it when ever I went to the dock...now I do it when ever I open the garage door.
Old 01-12-2003, 03:10 PM
loosing a ground somewhere? the brake warning circuit flashes until you start the car? i think my 74 does?
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 01-12-2003, 03:30 PM
John Rogers's Avatar
The effects of the fuse falling out are just as you describe. Scarry as hell isn't it! Did the ticking replay just start and what occured or what did you work on just before it started? If it just started, then I'd go for a ground problem. Good luck.
Old 01-12-2003, 04:18 PM
sacook's Avatar
I'll run through my grounding issues. I pulled the fresh-air unit from the dash. Also the fasten seatbelt light connection came off too. I'll run throgh all those aires again tomorrow.
Old 01-12-2003, 04:29 PM
sacook's Avatar
Could this tic be the brake warning light -- the light doesn't seem to be working. I'll put a meter on the light tomorrow
Old 01-12-2003, 05:39 PM
914 Geek
The same flasher circuit is used for the brake warning light. So yes, that is very likely what you are hearing.
--DD
Old 01-12-2003, 10:00 PM
VARam1500's Avatar
I have the same issue. I hear the ticking whenever the key is on, but don't get a corresponding flasing light unless the parking brake wire is grounded (my switch for that is rusted away). Since my car is not driveable yet, I've been forgetting about it until I can get the brakes done. I'm chalking it up to that for now in hopes that new fluid and pressure might reset the master cylinder (or I can finally find the reset button on it).
An interesting note that is the same on mine is that the cadence changes to that of the emergency flasher when that switch is turned on.
I know this isn't much help, but I can sympathize with your problem. Post the resolution if you find one and likewise I'll let you know if the brake work fixes mine. That probably won't come until later in the year, though!
--Case...
'75 1.8L L-jet 914
Old 01-13-2003, 05:19 AM
