How low can......
you go?
I need some feed back on rack spacers.
I'm aiming for 4.5 inches at the front (doughnuts to ground), which is about .75 in lower than it was.
Anyone BTDT...or close. How was the bump steer?
I should prolly just put some in and forgetaboutit, but I'm curious.
The car is headed for the alignment shop as soon as it is done.
Don't want to do it twice.
JPIII
Early Boxster
Old 02-14-2003, 01:16 PM
mike mueller's Avatar
I've always thought that you want the A-Arms // with the ground....what distance this puts the car depends on the dia. of the tires..........
'73 914, 1.7, with Boxster transmission in the future?
Old 02-14-2003, 03:52 PM
Hey! Nice Rack! "Celette"
rich's Avatar
I don't know much about the spacers but if your that low I can imagine you WILL have a real problem with the alignment and tie rod angle. I'd put in the spacers with out question.
Early Alien Sightings
914-M28/11 5.0 Hybrid (The Alien Sharkster)
I think I smell your blood in the water
WCC 04 done by the kids
Who says Aliens only abduct people.
Old 02-14-2003, 06:14 PM
cary's Avatar
JP, I lowered the Carrera TOO low. It smacks the front bumper doing parking lot approaches at speed. It makes a hell of a racket.
But I think the approach angle of the 914 is way more friendly. But check it out first.
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 02-14-2003, 07:40 PM
914 Geek
JP, you still have the suspension disassembled? (I.e., torsion bars out?) If so, just stick a toe measurement gizmo (two straight-pins in the tread with a string works pretty gud) and jack that one corner through its normal range of suspension travel. You can measure from the string to some known point and see how the toe changes. You can also look at the angle of the tie rod and see if you do need to move the rack up...
--DD
Old 02-14-2003, 07:50 PM
Stay away from my Member
campbellcj's Avatar
My car is quite low. The Welt spacer kit seems to deal with the worst of the bump steer issues, but is a "non-optimal" solution. I still get significant kickback in certain situations, like the huge fast sweeper (turn 8) at Willow. And I'm on small tires too. We will probably raise the strut spindles and use the ERP-style bump kit. The guy who is helping setup my suspension has a trick laser-based bump steer gauge that helps you put in exactly the right amount of spacers.
The little conical thingie in the lower left is the trick bit.
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 02-15-2003, 12:01 PM
Frankly, I've put my self into a box.
Some background:
Pre-project, the car sat 5.25 off the ground. The tires were 22.5 dia. The t-bars were not reindexed, but backed off to their lowest settings. Kick back was minimal.....less than either of my stock 911s.
The "new improved" set up is going to be 4.5 inches, but with 23.5 in dia tires.....for a drop (suspension wise) of 1.25 in.
This is gud cause there is a free negative camber gain of more than .5 deg....and I need all I can get....now for the ringer.
I'm going to "temporarily" be running the 22.5 dia tires.....good for 4 in ground clearance, nominal....2 inches at full compression.... tho I doubt it will ever see it with the 22mm
t-bars.
Chris, your adjustable tie rod ends look good.....how much (sigh)..I'm really getting tires of spending money on this effin' car.
JPIII
Early Boxster
Old 02-15-2003, 12:38 PM
