-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   case studs and P&C questions (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/94086-case-studs-p-c-questions.html)
woodman 01-13-2003 12:34 PM
I was just thinking about the (not too bad but bad enough) cylinder leakage I recently posted pictures of. Could the studs that connect them to the heads be coming loose? Is it a good idea on a high mileage engine to have these r&r'd?
One more question: New after market P&C's or cleanup the stock C's (if well in spec) and new P's and rings? I know Jake recommends using the stock C's because of superior cooling.
I've decided to rebuild as close to stock as possible this time. I don't want to spend this much $$ on an experiment.
Zeke 01-13-2003 12:53 PM
Did you have head gaskets in there when you pulled the motor down? If so, that is more likely the problem rather than the studs. Never hurts to check though. I sent you Email.
woodman 01-13-2003 01:02 PM
Yes, the head gasket was in there. It seemed to be leaking against the heads and case, that's why I thought about the case studs.
DuckRyder 01-13-2003 03:13 PM
L&N carries a ARP "case hardware and stud" set. Not to clear what it includes and it isn't cheap, but I would think that ARP would be fine stuff.
maf 914 01-13-2003 03:54 PM
The recommendation to reuse stock OEM cylinders is when going to larger bore 96 mm pistons. The common opinion is that the quality of aftermarket big bore cast iron cylinders is quite poor and that properly boring used OEM cylinders results in a better cylinder. I have not seen any discussions indicating superior cooling for OEM cast iron cylinders.
Mike
cnavarro 01-20-2003 03:57 PM
My mistake. I should clarify our web site. The hardware kit comes with the 16 head studs, 16 washers, and 16 "12 pt" nuts, all made out of ARP's 220,000 psi "ARP2000" material.
Take care,
Charles Navarro
LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
