another one of those might as well do it when it's off. repack the cv's and spring for new boots w/ the flange installed, don't forget the new gaskets.
good friend, it's really simple with them out of the car. esp if you have a set of those pointy tip pliers that open the c-clip. i read at one point here that the orientation of the cv is important during reasembly. i marked the outer face on mine and did one at a time to avoid confussion. i found atleast one loose bolt on each flange during removal. funny, a "click, click" noise i could never figure out went away after doing this procedure. cheap insurrance.
kevin kevin |
Hi Kevin,
Yes, a couple of mine were loose as well. I did mark the axles right, and left... outside, inside in case it made a difference. Thanks, John www.ghiaspecialties.com |
john, check the guest book at ghia specialties.
kevin |
Hi Kevin,
My guestbook shows no new entries since Oct. Maybe something is wrong with it. Did you put in an entry? Thanks, John www.ghiaspecialties.com |
i made an entry this weekend. w/ regards to two local guys "talking" at pelican. did another this am.
kevin |
Hi Kevin,
I'll have the web master get it fixed. Thanks for the heads-up. John www.ghiaspecialties.com |
| All times are GMT -8. The time now is 03:36 PM. |
