				electical questions most likely one of many questions
			I just got done hooking my wiring harness up to the front of the car and the gauges.  just for kicks I hook my battery charger up to postive (via the engine harness both reds)and a ground under the dash to see what works.  I don't want to have to pull everything apart again if something doesnt.
				So my questions are: Should the hazard switch be making a buzzing sound when turned on. Should the headlight motors work. Right now all I hear is a clicking sound. I have no headlights or signal lights hook up yet. And shouldn't my dash lights come on. My fan works. One more then to mention is I only have the charger on the 2amp charge. Could that be the problem not enough amps. I'm going back to work on it in 2 hours so any help or insight would be appreciated
	1973 914-6 3.2 Motronic  |
			Your particular battery charger may not have enough oomph to light up the stuff you're playing with.  Clicks and buzzes (as opposed to stuff working) can be a symptom of not enough amps to get stuff going.  Use your battery.
	John Yellow '76 914 3.2 YPAF  |
			Yea thats what I thought too.  I will be hooking up the battery.
			Well it wasn't the battery but a bad fuse.  Hazard is still buzzing when turn it on and so is the turn signals.  This has got to be a common problem.  Any help.  It could be something simple but I am just so overwhelmed by the rewiring that I may be overlooking it.
			Bad relay or relay circuit?
	Brian Ludden Charlotte NC '76 914 2k2 VW New Beetle Turbo S  |
			bfrenz,
					If you connected a battery charger to the wiring harness without a battery being installed, you may have damaged one or more of the electrical components in the system. The battery acts like a massive capacitor stabilizing the voltage to a flat 12.5 to 13.5 volts (ball park). The typical battery charger puts out pulsating DC with voltage peaks as high as 40 or more volts. Without the battery installed, those relays, buzzers, flashers, etc., are looking at what is essentially AC volts. Not good. Phil  |
