echecsqueen's Avatar
914 2.0 engine in a 912 body
Can anyone help me by sending me a photo or PDF of pertinent pages in the owner's manual so I can ID some parts/ troubleshoot some problems. My car is a mismatch so I am not sure where to look. Thanks in advance.
engine 1975 or 1976 GC 914 2.0
transmission 901 5 speed
1988 911 Coupe Granite Green "Frogger"
1966 912R Coupe Stone Grey outlaw -"'Tilda"
1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter"
1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio)
1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001
Old 06-18-2017, 11:55 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
What pages from which owner's manual? 914 or 912?
The GC motor was used in the 75-76 2.0 914, and also in the 76 912E. But the engine number was evidently on the fan shroud of the 912E, and it had L-jetronic fuel injection instead of D-jetronic as used on the 2.0 liter 914s.
All of the 912s except for the 76 912E used a 901 transmission (either 4-speed or 5-speed), and all 914s used a "914" transmission which was based very heavily on the 901 trans.
You can post a pic here and ask your questions as well.
--DD
Old 06-18-2017, 12:15 PM
Thank you.
For the 914 1975-6 engine and transmission I was hoping to have the pages that had any information about the engine and transmission.
For the 912 1966 I was hoping to have the pages with interior and exterior features...everything except engine and transmission.
I have too many questions to even know where to begin It would help if I had a diagram of parts etc.
Old 06-18-2017, 12:30 PM
I now have what I need for the 912...hoping to get only engine information on 914 1975 or 1976.
thank you.
Old 06-19-2017, 04:51 AM
Administrator
What kind of information?
Here is some: Porsche 914 (1970-1976) Technical Articles - Pelican Parts
Links to more information: Pelican Parts - Porsche 914 World
Tech specs: Pelican Parts - Porsche 914 Parts Listings & Diagrams
Holds about 4 qts of oil (a bit less, but it's fine to over-fill a touch). Valve clearances for stock valves are 0.006" intake and 0.008" exhaust. Oil sump screen should be cleaned but the retaining nut requires a very very low torque value, like NINE foot-lbs. Ignition timing is 27 deg BTDC at 3500 RPM with the vacuum hoses disconnected from the distributor. Points gap is pretty standard, something like 0.016"; a business card is actually pretty close!!
--DD
Old 06-19-2017, 08:47 AM
thank you Dave
Old 06-19-2017, 04:40 PM
Slippery Slope Expert
Steam Driver's Avatar
(Not totally relevant)
This thread triggered a flashback. Do any of you "old timers" (i.e. who were around in 1970 when the 914 came out) remember the furor over the 914 not being a real Porsche because of its VW engine? There was a guy down in TX (as I remember) who immediately began trying to fit a 912 engine into a brand new 914! So now it's come full circle!
As I recall the person was someone relatively well known in PCA at the time, and the project ran a few times in Pano and then disappeared, so I don't know if it was ever completed, found to be a bad idea or what.
Anyone else remember this?
Old 06-29-2017, 09:18 AM
